[Mapserver-users] pb with projection settings
Richard Greenwood
Rich at GreenwoodMap.com
Mon Nov 24 09:41:16 EST 2003
--=======543C3DEA=======
Content-Type: text/plain; x-avg-checked=avg-ok-2D4A5; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 8bit
At 06:46 AM 11/24/2003, you wrote:
>Hi list,
>I've got a problem with the use of the proj.lib in Mapserver: I would like
>to display some map in Italy but I don't succeed in setting the right
>projection parameters. I get always the same distorted map if I change the
>parameters in the file proj_def.dat or when I change the projection
>settings in the mapfile (for the main projection and for the layer
>reprojections). Has someone any idea about the solution of these problem ??
>Thank you very much.
You must set two projections; the target projection and the source
projection. The target projection is the output projection. It is set for
the entire map file. You have is set for lat / long in your attached example.
The source projection is for individual layers. It is only required for
layers that are not in your desired output projection. You must tell
mapserver what projection these layers are in so that they can be
reprojected into the output target projection.
You appear to be using MapInfo, which can reproject layers for you. You
might consider doing this because it will make your map file simpler, and
because there will be less processing required of mapserver. You reproject
your data only once, rather than for every map request.
When you post a sample map file to the list, it is nice if you clean it up
first. Try to remove blocks that are commented out and unnecessary layers
so that we can more easily see what is going on.
Rich
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
Rich <at> GreenwoodMap <dot> com
(307) 733-0203
http://www.GreenwoodMap.com
--=======543C3DEA=======--
