[Mapserver-users] pb with projection settings
Frank Warmerdam
warmerdam at pobox.com
Mon Nov 24 09:02:42 EST 2003
Yvain Ballini wrote:
> Hi list,
> I've got a problem with the use of the proj.lib in Mapserver: I would
> like to display some map in Italy but I don't succeed in setting the
> right projection parameters. I get always the same distorted map if I
> change the parameters in the file proj_def.dat or when I change the
> projection settings in the mapfile (for the main projection and for the
> layer reprojections). Has someone any idea about the solution of these
> problem ??
> Thank you very much.
> PROJECTION
> "proj=longlat"
> "ellps=intl"
> "units=m"
> "towgs84=-225,-65,9,0,0,0,0"
> "no_defs"
> #"proj=utm"
> #"ellps=WGS84"
> #"zone=15"
> #"towgs84=0,0,0"
> #"north"
> #"no_defs"
> END
Yvain,
If you choose to display a map on a geographic grid you will tend to get a
somewhat distorted view. On approach to try and work around this would
be to add the PROJECTION declarations for each of the layers, marking them
as being proj=latlong ellps=intl, and then add a map level declaration for
proj=utm zone=32 ellps=intl. This would cause the data to be reprojected
into UTM (I think zone 32 is roughly right for Italy).
I would add two notes:
o Don't use units=m for proj=latlong, it doesn't make any sense.
o When emailing out your map file requesting support from the list try
reducing it to the minimum required to reproduce your problem. I almost
gave up scanning through your long mapfile to see if there were any other
significant declarations.
Good luck,
and watch the world go round - Rush | Geospatial Programmer for Rent
