[Mapserver-users] pb with projection settings
Yvain Ballini
yvain.ballini at seat.it
Mon Nov 24 08:46:14 EST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_015C_01C3B299.B5D261F0
Content-Transfer-Encoding: quoted-printable
Content-Type: text/plain;
charset="iso-8859-1"
Hi list,
I've got a problem with the use of the proj.lib in Mapserver: I would =
like to display some map in Italy but I don't succeed in setting the =
right projection parameters. I get always the same distorted map if I =
change the parameters in the file proj_def.dat or when I change the =
projection settings in the mapfile (for the main projection and for the =
layer reprojections). Has someone any idea about the solution of these =
problem ??
Thank you very much.
there is above the mapfile that I'm using:
# Start of map file
NAME DEV
STATUS ON
SIZE 430 380
#SIZE 150 150
EXTENT 7.680 45.06 7.685 45.06
#EXTENT 7.680 45.06 7.683 45.06
#SIZE 1000 1000
#EXTENT 7.60 45.03 7.75 45.09
#UNITS METERS
DEBUG TRUE
SHAPEPATH "data"
IMAGECOLOR 189 198 206
PROJECTION
"proj=3Dlonglat"=20
"ellps=3Dintl"=20
"units=3Dm"
"towgs84=3D-225,-65,9,0,0,0,0"=20
"no_defs"=20
#"proj=3Dutm"
#"ellps=3DWGS84"
#"zone=3D15"
#"towgs84=3D0,0,0"
#"north"
#"no_defs"=20
END
#OUTPUTFORMAT
# NAME gif
# DRIVER "GD/GIF"
# MIMETYPE "image/gif"
# IMAGEMODE PC256
# EXTENSION "gif"
#END
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
END
#OUTPUTFORMAT
# NAME jpeg
# DRIVER "GD/JPEG"
# MIMETYPE "image/jpeg"
# IMAGEMODE RGB
# EXTENSION "jpg"
#END
#OUTPUTFORMAT
# NAME wbmp
# DRIVER "GD/WBMP"
# MIMETYPE "image/wbmp"
# IMAGEMODE PC256
# EXTENSION "wbmp"
#END
#OUTPUTFORMAT
# NAME swf
# DRIVER "SWF"
# MIMETYPE "application/x-shockwave-flash"
# EXTENSION "swf"
# IMAGEMODE PC256
# FORMATOPTION "OUTPUT_MOVIE=3DSINGLE"
#END
#IMAGETYPE SWF
IMAGETYPE PNG
#IMAGETYPE PDF
#PROJECTION
# proj=3Dlonglat=20
# ellps=3DWGS84
# datum=3DWGS84=20
# zone=3D50
# no_defs
# "zone=3D15"
# "north"
# "no_defs"
# OR:=20
# "init=3Depsg:26915"
#END
WEB
HEADER demo_header.html
TEMPLATE demo.html
FOOTER demo_footer.html
#MINSCALE 1000
#MAXSCALE 1550000
IMAGEPATH "set in demo_init.html"
IMAGEURL "set in demo_init.html"
END
FONTSET "c:\windows\fonts\fonts.txt"
#REFERENCE
# IMAGE graphics/reference.gif
# EXTENT 393234.393701263 5205405.16440722 495769.579718949 =
5307959.02579127
# SIZE 120 120
# STATUS ON
# COLOR -1 -1 -1
# OUTLINECOLOR 255 0 0
#END
SYMBOL
NAME 'carto_line'
TYPE CARTOLINE
#Linecap - ROUND, SQUARE, TRIANGLE, BUTT - default BUTT
LINECAP BUTT
#Linejoin - ROUND, BEVEL, MITER - default NONE
LINEJOIN BEVEL
LINEJOINMAXSIZE 5
END
SYMBOL
NAME 'cline'
TYPE ellipse
POINTS=20
1 1
END
END
LAYER
NAME parchi_navtech
STATUS OFF
DATA parkcity_region
TYPE POLYGON
LABELITEM "NAME"
CLASS
LABEL
#ANGLE AUTO
#BUFFER 1
#PARTIALS FALSE
#FORCE TRUE
FONT "verdana"
ANTIALIAS TRUE
POSITION AUTO
SIZE 5
TYPE TRUETYPE
COLOR 255 255 255
END
STYLE
#COLOR 66 132 0
COLOR 77 199 63
ANTIALIAS TRUE
END
END
END # parchi navtech
LAYER
NAME aree_navtech
STATUS OFF
DATA landuseA_region
TYPE POLYGON
LABELITEM "NAME"
CLASS
LABEL
#ANGLE AUTO
#BUFFER 1
#PARTIALS FALSE
#FORCE TRUE
FONT "verdana"
ANTIALIAS TRUE
POSITION AUTO
SIZE 5
TYPE TRUETYPE
COLOR 255 255 255
END
STYLE
#COLOR 255 165 115
COLOR 179 181 81
ANTIALIAS TRUE
END
END
END # corsi d'acqua navtech
LAYER
NAME acqua_navtech
STATUS OFF
DATA waterwys_region
TYPE POLYGON
#LABELITEM "StNm_Base"
CLASS
STYLE
#COLOR 165 214 255
#COLOR 165 165 165
ANTIALIAS TRUE
COLOR 64 154 253
END
END
LAYER
NAME acqua1_navtech
STATUS OFF
DATA waterwys_polyline
TYPE LINE
CLASS
STYLE
SIZE 1
#COLOR 165 214 255
COLOR 64 154 253
ANTIALIAS TRUE
END
END
LAYER
NAME pedonali_navtech
STATUS OFF
DATA pedonali3_polyline
#CONNECTIONTYPE OGR
#CONNECTION "c:\mapserver\itasca\data\pedonali1.tab"
TYPE LINE
CLASS
STYLE=20
SYMBOL 'carto_line'
SIZE 3
#COLOR 181 222 255
COLOR 120 140 255
ANTIALIAS TRUE
END
END
END # pedonali navtech
#LAYER
# NAME vie_navtech
#MAXSCALE 600000
# STATUS OFF
# CONNECTIONTYPE OGR
# CONNECTION "c:\mapserver\itasca\data\vie_e_corsi.tab"
#DATA vie3_polyline
# END=20
# TYPE LINE
# CLASS
# STYLE=20
# SYMBOL 'carto_line'
# SIZE 9
#COLOR 181 222 255
# COLOR 120 140 255
# ANTIALIAS TRUE
# END
# END
#END # vie navtech
LAYER
NAME vie_navtech
PROJECTION
#"proj=3Daeqd"
#"ellps=3DWGS60"
#"units=3Dm"
#"towgs84=3D0,0,0"
#"no_defs"
"proj=3Dlonglat"=20
"ellps=3Dintl"=20
"units=3Dm"
"no_defs"=20
END
#MAXSCALE 600000
STATUS OFF
DATA vie3_polyline
#CONNECTIONTYPE OGR
#CONNECTION "c:\mapserver\itasca\data\vie1.tab"
TYPE LINE
CLASS
STYLE=20
SYMBOL 'carto_line'
SIZE 6
#COLOR 181 222 255
COLOR 120 140 255
ANTIALIAS TRUE
END
END
END # vie navtech
LAYER
NAME controviali_navtech
STATUS OFF
DATA controviali2_polyline
#CONNECTIONTYPE OGR
#CONNECTION "c:\mapserver\itasca\data\controviali1.tab"
TYPE LINE
CLASS
STYLE=20
SYMBOL 'carto_line'
SIZE 4
#COLOR 181 222 255
COLOR 120 140 255
ANTIALIAS TRUE
END
END
END # controviali navtech
LAYER
NAME controviali_navtech2
STATUS OFF
#CONNECTIONTYPE OGR
TYPE LINE
CLASS
STYLE=20
SYMBOL 'carto_line'
SIZE 2
COLOR 255 255 255
ANTIALIAS TRUE
END
END
LAYER
NAME corsi_navtech
#MAXSCALE 600000
STATUS OFF
DATA corsi5_polyline
#CONNECTIONTYPE OGR
#CONNECTION "c:\mapserver\itasca\data\corsi1.tab"
TYPE LINE
CLASS
STYLE=20
SYMBOL 'carto_line'
SIZE 9
COLOR 120 140 255
ANTIALIAS TRUE
END
END
END # corsi navtech
LAYER
NAME importanti_navtech
STATUS OFF
DATA importanti5_polyline
#CONNECTIONTYPE OGR
#CONNECTION "c:\mapserver\itasca\data\importanti1.tab"
TYPE LINE
CLASS
STYLE=20
SYMBOL 'carto_line'
SIZE 8
#COLOR 156 202 156
COLOR 88 174 51
ANTIALIAS TRUE
END
END
END # importanti navtech
#LAYER
# NAME statali_navtech
# STATUS OFF
# CONNECTION "c:\mapserver\itasca\data\statali1.tab"
# TYPE LINE
# CLASS
# STYLE=20
# SIZE 8
#COLOR 156 202 156
# COLOR 88 174 51
# ANTIALIAS TRUE
# END
# END
#END # statali navtech
LAYER
NAME pedonali_navtech2
STATUS OFF
#CONNECTIONTYPE OGR
TYPE LINE
LABELCACHE ON
CLASS
LABEL
ANGLE AUTO
FONT "verdana"
#BUFFER 1
#PARTIALS FALSE
ANTIALIAS TRUE
POSITION CC
SIZE 5
TYPE TRUETYPE
COLOR 0 0 0
END
STYLE=20
SYMBOL 'carto_line'
#SIZE 2
SIZE 3
#COLOR 217 222 255
COLOR 120 140 255
ANTIALIAS TRUE
END
END
LAYER
NAME vie_navtech2
#MAXSCALE 600000
STATUS OFF
DATA vie3_polyline
#CONNECTIONTYPE OGR
LABELCACHE ON
TYPE LINE
CLASS
LABEL
ANGLE AUTO
BUFFER 1
PARTIALS FALSE
FORCE TRUE
FONT "verdana"
ANTIALIAS TRUE
POSITION CC
SIZE 7
TYPE TRUETYPE
COLOR 0 0 0
END
STYLE
SYMBOL 'carto_line'
SIZE 4
COLOR 255 255 255
ANTIALIAS TRUE
END
END
END # vie navtech
LAYER
NAME corsi_navtech2
STATUS OFF
#CONNECTIONTYPE OGR
LABELCACHE ON
TYPE LINE
CLASS
LABEL
ANGLE AUTO
BUFFER 1
#PARTIALS FALSE
FONT "verdana"
#FORCE TRUE
ANTIALIAS TRUE
MINDISTANCE 2
POSITION CC
SIZE 7
TYPE TRUETYPE
COLOR 0 0 0
END
STYLE=20
SYMBOL 'carto_line'
SIZE 7
COLOR 255 255 255
ANTIALIAS TRUE
END
END
END # corsi navtech
LAYER
NAME importanti_navtech2
STATUS OFF
#CONNECTIONTYPE OGR
LABELCACHE ON
TYPE LINE
CLASS
LABEL
ANGLE AUTO
BUFFER 1
#PARTIALS FALSE
FONT "verdana"
ANTIALIAS TRUE
MINDISTANCE 2
#FORCE TRUE
POSITION CC
SIZE 7
TYPE TRUETYPE
COLOR 0 0 0
END
STYLE
SYMBOL 'carto_line'
SIZE 4
#COLOR 255 255 132
COLOR 255 255 159
#color 255 255 255
ANTIALIAS TRUE
END
END
#LAYER
# NAME statali_navtech2
# STATUS OFF
# LABELITEM "StNm_Base"
# LABELCACHE ON
# TYPE LINE
# CLASS
# LABEL
# ANGLE AUTO
# BUFFER 1
# #PARTIALS FALSE
# FONT "verdana"
# ANTIALIAS TRUE
# MINDISTANCE 2
#FORCE TRUE
# POSITION CC
# SIZE 7
# TYPE TRUETYPE
# COLOR 0 0 0
# END
# STYLE
# SIZE 4
#COLOR 255 255 132
# COLOR 255 255 159
#color 255 255 255
# ANTIALIAS TRUE
# END
# END
#END
LAYER
NAME freccie_navtech
STATUS OFF
#CONNECTIONTYPE OGR
#CONNECTION "c:\mapserver\itasca\data\arrow.tab"
DATA arrow_font_point
TYPE POINT
CLASS
STYLE
SYMBOL 'cline'
size 2
COLOR 245 88 128
ANTIALIAS TRUE
END
END
END
END # Map File
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1106" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Hi list,<BR>I've got a problem with the =
use of the=20
proj.lib in Mapserver: I would like to display some map in Italy but I =
don't=20
succeed in setting the right projection parameters. I get always the =
same=20
distorted map if I change the parameters in the file proj_def.dat or =
when I=20
change the projection settings in the mapfile (for the main projection =
and for=20
the layer reprojections). Has someone any idea about the solution of =
these=20
problem ??<BR>Thank you very much.<BR><BR>there is above the mapfile =
that I'm=20
using:<BR><BR>#<BR># Start of map file<BR>#<BR>NAME DEV<BR>STATUS =
ON<BR>SIZE 430=20
380<BR>#SIZE 150 150<BR>EXTENT 7.680 45.06 7.685 45.06<BR>#EXTENT 7.680 =
45.06=20
7.683 45.06<BR><BR>#SIZE 1000 1000<BR>#EXTENT 7.60 45.03 7.75=20
45.09<BR><BR>#UNITS METERS<BR><BR>DEBUG TRUE<BR>SHAPEPATH =
"data"<BR>IMAGECOLOR=20
189 198 206<BR><BR>PROJECTION<BR><BR>"proj=3Dlonglat" <BR>"ellps=3Dintl" =
<BR>"units=3Dm"<BR>"towgs84=3D-225,-65,9,0,0,0,0" <BR>"no_defs"=20
<BR><BR><BR>#"proj=3Dutm"<BR>#"ellps=3DWGS84"<BR>#"zone=3D15"<BR>#"towgs8=
4=3D0,0,0"<BR>#"north"<BR>#"no_defs"=20
<BR><BR>END<BR><BR>#OUTPUTFORMAT<BR># NAME gif<BR># DRIVER "GD/GIF"<BR># =
MIMETYPE "image/gif"<BR># IMAGEMODE PC256<BR># EXTENSION=20
"gif"<BR>#END<BR><BR>OUTPUTFORMAT<BR>NAME png<BR>DRIVER =
"GD/PNG"<BR>MIMETYPE=20
"image/png"<BR>IMAGEMODE RGB<BR>EXTENSION =
"png"<BR>END<BR><BR>#OUTPUTFORMAT<BR>#=20
NAME jpeg<BR># DRIVER "GD/JPEG"<BR># MIMETYPE "image/jpeg"<BR># =
IMAGEMODE=20
RGB<BR># EXTENSION "jpg"<BR>#END<BR><BR>#OUTPUTFORMAT<BR># NAME =
wbmp<BR># DRIVER=20
"GD/WBMP"<BR># MIMETYPE "image/wbmp"<BR># IMAGEMODE PC256<BR># EXTENSION =
"wbmp"<BR>#END<BR><BR>#OUTPUTFORMAT<BR># NAME swf<BR># DRIVER "SWF"<BR># =
MIMETYPE "application/x-shockwave-flash"<BR># EXTENSION "swf"<BR># =
IMAGEMODE=20
PC256<BR># FORMATOPTION =
"OUTPUT_MOVIE=3DSINGLE"<BR>#END<BR><BR>#IMAGETYPE=20
SWF<BR>IMAGETYPE PNG<BR>#IMAGETYPE PDF<BR><BR>#PROJECTION<BR># =
proj=3Dlonglat=20
<BR># ellps=3DWGS84<BR># datum=3DWGS84 <BR># zone=3D50<BR># no_defs<BR># =
"zone=3D15"<BR># "north"<BR># "no_defs"<BR>#<BR># OR: <BR>#<BR>#=20
"init=3Depsg:26915"<BR>#END<BR><BR>WEB<BR>HEADER =
demo_header.html<BR>TEMPLATE=20
demo.html<BR>FOOTER demo_footer.html<BR>#MINSCALE 1000<BR>#MAXSCALE=20
1550000<BR>IMAGEPATH "set in demo_init.html"<BR>IMAGEURL "set in=20
demo_init.html"<BR>END<BR>FONTSET=20
"c:\windows\fonts\fonts.txt"<BR><BR>#REFERENCE<BR># IMAGE=20
graphics/reference.gif<BR># EXTENT 393234.393701263 5205405.16440722=20
495769.579718949 5307959.02579127<BR># SIZE 120 120<BR># STATUS ON<BR># =
COLOR -1=20
-1 -1<BR># OUTLINECOLOR 255 0 0<BR>#END<BR><BR>SYMBOL<BR>NAME=20
'carto_line'<BR>TYPE CARTOLINE<BR>#Linecap - ROUND, SQUARE, TRIANGLE, =
BUTT -=20
default BUTT<BR>LINECAP BUTT<BR>#Linejoin - ROUND, BEVEL, MITER - =
default=20
NONE<BR>LINEJOIN BEVEL<BR>LINEJOINMAXSIZE 5<BR>END<BR><BR>SYMBOL<BR>NAME =
'cline'<BR>TYPE ellipse<BR>POINTS <BR>1 =
1<BR>END<BR>END<BR><BR>LAYER<BR>NAME=20
parchi_navtech<BR>STATUS OFF<BR>DATA parkcity_region<BR>TYPE=20
POLYGON<BR>LABELITEM "NAME"<BR>CLASS<BR>LABEL<BR>#ANGLE AUTO<BR>#BUFFER=20
1<BR>#PARTIALS FALSE<BR>#FORCE TRUE<BR>FONT "verdana"<BR>ANTIALIAS=20
TRUE<BR>POSITION AUTO<BR>SIZE 5<BR>TYPE TRUETYPE<BR>COLOR 255 255=20
255<BR>END<BR>STYLE<BR>#COLOR 66 132 0<BR>COLOR 77 199 63<BR>ANTIALIAS=20
TRUE<BR>END<BR>END<BR>END # parchi navtech<BR><BR>LAYER<BR>NAME=20
aree_navtech<BR>STATUS OFF<BR>DATA landuseA_region<BR>TYPE =
POLYGON<BR>LABELITEM=20
"NAME"<BR>CLASS<BR>LABEL<BR>#ANGLE AUTO<BR>#BUFFER 1<BR>#PARTIALS=20
FALSE<BR>#FORCE TRUE<BR>FONT "verdana"<BR>ANTIALIAS TRUE<BR>POSITION=20
AUTO<BR>SIZE 5<BR>TYPE TRUETYPE<BR>COLOR 255 255 =
255<BR>END<BR>STYLE<BR>#COLOR=20
255 165 115<BR>COLOR 179 181 81<BR>ANTIALIAS TRUE<BR>END<BR>END<BR>END # =
corsi=20
d'acqua navtech<BR><BR>LAYER<BR>NAME acqua_navtech<BR>STATUS OFF<BR>DATA =
waterwys_region<BR>TYPE POLYGON<BR>#LABELITEM=20
"StNm_Base"<BR>CLASS<BR>STYLE<BR>#COLOR 165 214 255<BR>#COLOR 165 165=20
165<BR>ANTIALIAS TRUE<BR>COLOR 64 154 253<BR>END<BR>END<BR>END # corsi =
d'acqua=20
navtech<BR><BR>LAYER<BR>NAME acqua1_navtech<BR>STATUS OFF<BR>DATA=20
waterwys_polyline<BR>TYPE LINE<BR>#LABELITEM=20
"StNm_Base"<BR>CLASS<BR>STYLE<BR>SIZE 1<BR>#COLOR 165 214 255<BR>COLOR =
64 154=20
253<BR>ANTIALIAS TRUE<BR>END<BR>END<BR>END # parchi =
pedonali_navtech<BR>STATUS OFF<BR>DATA =
pedonali3_polyline<BR>#CONNECTIONTYPE=20
OGR<BR>#CONNECTION "c:\mapserver\itasca\data\pedonali1.tab"<BR>TYPE=20
LINE<BR>CLASS<BR>STYLE <BR>SYMBOL 'carto_line'<BR>SIZE 3<BR>#COLOR 181 =
222=20
255<BR>COLOR 120 140 255<BR>ANTIALIAS TRUE<BR>END<BR>END<BR>END # =
pedonali=20
navtech<BR><BR>#LAYER<BR># NAME vie_navtech<BR>#MAXSCALE 600000<BR># =
STATUS=20
OFF<BR># CONNECTIONTYPE OGR<BR># CONNECTION=20
"c:\mapserver\itasca\data\vie_e_corsi.tab"<BR>#DATA =
vie3_polyline<BR><BR># END=20
<BR><BR># TYPE LINE<BR># CLASS<BR># STYLE <BR># SYMBOL 'carto_line'<BR># =
SIZE=20
9<BR>#COLOR 181 222 255<BR># COLOR 120 140 255<BR># ANTIALIAS TRUE<BR># =
END<BR>#=20
END<BR>#END # vie navtech<BR><BR>LAYER<BR>NAME=20
vie_navtech<BR><BR>PROJECTION<BR>#"proj=3Daeqd"<BR>#"ellps=3DWGS60"<BR>#"=
units=3Dm"<BR>#"towgs84=3D0,0,0"<BR>#"no_defs"<BR>"proj=3Dlonglat"=20
<BR>"ellps=3Dintl" <BR>"units=3Dm"<BR>"towgs84=3D-225,-65,9,0,0,0,0" =
<BR>"no_defs"=20
<BR>END<BR><BR>#MAXSCALE 600000<BR>STATUS OFF<BR>DATA=20
vie3_polyline<BR>#CONNECTIONTYPE OGR<BR>#CONNECTION=20
"c:\mapserver\itasca\data\vie1.tab"<BR>TYPE LINE<BR>CLASS<BR>STYLE =
<BR>SYMBOL=20
'carto_line'<BR>SIZE 6<BR>#COLOR 181 222 255<BR>COLOR 120 140 =
255<BR>ANTIALIAS=20
TRUE<BR>END<BR>END<BR>END # vie navtech<BR><BR>LAYER<BR>NAME=20
controviali_navtech<BR>STATUS OFF<BR>DATA=20
controviali2_polyline<BR>#CONNECTIONTYPE OGR<BR>#CONNECTION=20
"c:\mapserver\itasca\data\controviali1.tab"<BR>TYPE =
LINE<BR>CLASS<BR>STYLE=20
<BR>SYMBOL 'carto_line'<BR>SIZE 4<BR>#COLOR 181 222 255<BR>COLOR 120 140 =
255<BR>ANTIALIAS TRUE<BR>END<BR>END<BR>END # controviali=20
navtech<BR><BR>LAYER<BR>NAME controviali_navtech2<BR>STATUS OFF<BR>DATA=20
<BR>SYMBOL 'carto_line'<BR>SIZE 2<BR>COLOR 255 255 255<BR>ANTIALIAS=20
TRUE<BR>END<BR>END<BR>END # controviali navtech<BR><BR>LAYER<BR>NAME=20
corsi_navtech<BR>#MAXSCALE 600000<BR>STATUS OFF<BR>DATA=20
corsi5_polyline<BR>#CONNECTIONTYPE OGR<BR>#CONNECTION=20
"c:\mapserver\itasca\data\corsi1.tab"<BR>TYPE LINE<BR>CLASS<BR>STYLE =
<BR>SYMBOL=20
'carto_line'<BR>SIZE 9<BR>COLOR 120 140 255<BR>ANTIALIAS=20
TRUE<BR>END<BR>END<BR>END # corsi navtech<BR><BR>LAYER<BR>NAME=20
importanti_navtech<BR>STATUS OFF<BR>DATA =
importanti5_polyline<BR>#CONNECTIONTYPE=20
OGR<BR>#CONNECTION "c:\mapserver\itasca\data\importanti1.tab"<BR>TYPE=20
LINE<BR>CLASS<BR>STYLE <BR>SYMBOL 'carto_line'<BR>SIZE 8<BR>#COLOR 156 =
202=20
156<BR>COLOR 88 174 51<BR>ANTIALIAS TRUE<BR>END<BR>END<BR>END # =
importanti=20
navtech<BR><BR>#LAYER<BR># NAME statali_navtech<BR># STATUS OFF<BR>#=20
CONNECTIONTYPE OGR<BR># CONNECTION =
"c:\mapserver\itasca\data\statali1.tab"<BR>#=20
TYPE LINE<BR># CLASS<BR># STYLE <BR># SYMBOL 'carto_line'<BR># SIZE =
8<BR>#COLOR=20
156 202 156<BR># COLOR 88 174 51<BR># ANTIALIAS TRUE<BR># END<BR># =
END<BR>#END #=20
statali navtech<BR><BR>LAYER<BR>NAME pedonali_navtech2<BR>STATUS =
OFF<BR>DATA=20
pedonali3_polyline<BR>#CONNECTIONTYPE OGR<BR>#CONNECTION=20
"c:\mapserver\itasca\data\pedonali1.tab"<BR>TYPE LINE<BR>LABELITEM=20
"StNm_Base"<BR>LABELCACHE ON<BR>CLASS<BR>LABEL<BR>ANGLE AUTO<BR>FONT=20
"verdana"<BR>#BUFFER 1<BR>#PARTIALS FALSE<BR>ANTIALIAS TRUE<BR>POSITION=20
CC<BR>SIZE 5<BR>TYPE TRUETYPE<BR>COLOR 0 0 0<BR>END<BR>STYLE <BR>SYMBOL=20
'carto_line'<BR>#SIZE 2<BR>SIZE 3<BR>#COLOR 217 222 255<BR>COLOR 120 140 =
255<BR>ANTIALIAS TRUE<BR>END<BR>END<BR>END # pedonali=20
navtech<BR><BR>LAYER<BR>NAME vie_navtech2<BR>#MAXSCALE 600000<BR>STATUS=20
OFF<BR>DATA vie3_polyline<BR>#CONNECTIONTYPE OGR<BR>#CONNECTION=20
"c:\mapserver\itasca\data\vie1.tab"<BR>LABELITEM =
"StNm_Base"<BR>LABELCACHE=20
ON<BR>TYPE LINE<BR>CLASS<BR>LABEL<BR>ANGLE AUTO<BR>BUFFER 1<BR>PARTIALS=20
FALSE<BR>FORCE TRUE<BR>FONT "verdana"<BR>ANTIALIAS TRUE<BR>POSITION =
CC<BR>SIZE=20
7<BR>TYPE TRUETYPE<BR>COLOR 0 0 0<BR>END<BR>STYLE<BR>SYMBOL =
'carto_line'<BR>SIZE=20
4<BR>COLOR 255 255 255<BR>ANTIALIAS TRUE<BR>END<BR>END<BR>END # vie=20
navtech<BR><BR>LAYER<BR>NAME corsi_navtech2<BR>STATUS OFF<BR>DATA=20
"c:\mapserver\itasca\data\corsi1.tab"<BR>LABELITEM =
ON<BR>TYPE LINE<BR>CLASS<BR>LABEL<BR>ANGLE AUTO<BR>BUFFER 1<BR>#PARTIALS =
FALSE<BR>FONT "verdana"<BR>#FORCE TRUE<BR>ANTIALIAS TRUE<BR>MINDISTANCE=20
2<BR>POSITION CC<BR>SIZE 7<BR>TYPE TRUETYPE<BR>COLOR 0 0 =
0<BR>END<BR>STYLE=20
<BR>SYMBOL 'carto_line'<BR>SIZE 7<BR>COLOR 255 255 255<BR>ANTIALIAS=20
importanti_navtech2<BR>STATUS OFF<BR>DATA=20
importanti5_polyline<BR>#CONNECTIONTYPE OGR<BR>#CONNECTION=20
"c:\mapserver\itasca\data\importanti1.tab"<BR>LABELITEM=20
"StNm_Base"<BR>LABELCACHE ON<BR>TYPE LINE<BR>CLASS<BR>LABEL<BR>ANGLE=20
AUTO<BR>BUFFER 1<BR>#PARTIALS FALSE<BR>FONT "verdana"<BR>ANTIALIAS=20
TRUE<BR>MINDISTANCE 2<BR>#FORCE TRUE<BR>POSITION CC<BR>SIZE 7<BR>TYPE=20
TRUETYPE<BR>COLOR 0 0 0<BR>END<BR>STYLE<BR>SYMBOL 'carto_line'<BR>SIZE=20
4<BR>#COLOR 255 255 132<BR>COLOR 255 255 159<BR>#color 255 255 =
255<BR>ANTIALIAS=20
TRUE<BR>END<BR>END<BR>END # importanti navtech<BR><BR>#LAYER<BR># NAME=20
statali_navtech2<BR># STATUS OFF<BR># CONNECTIONTYPE OGR<BR># CONNECTION =
"c:\mapserver\itasca\data\statali1.tab"<BR># LABELITEM "StNm_Base"<BR>#=20
LABELCACHE ON<BR># TYPE LINE<BR># CLASS<BR># LABEL<BR># ANGLE AUTO<BR># =
BUFFER=20
1<BR># #PARTIALS FALSE<BR># FONT "verdana"<BR># ANTIALIAS TRUE<BR># =
MINDISTANCE=20
2<BR>#FORCE TRUE<BR># POSITION CC<BR># SIZE 7<BR># TYPE TRUETYPE<BR># =
COLOR 0 0=20
0<BR># END<BR># STYLE<BR># SYMBOL 'carto_line'<BR># SIZE 4<BR>#COLOR 255 =
255=20
132<BR># COLOR 255 255 159<BR>#color 255 255 255<BR># ANTIALIAS =
TRUE<BR>#=20
END<BR># END<BR>#END<BR><BR>LAYER<BR>NAME freccie_navtech<BR>STATUS=20
OFF<BR>#CONNECTIONTYPE OGR<BR>#CONNECTION=20
"c:\mapserver\itasca\data\arrow.tab"<BR>DATA arrow_font_point<BR>TYPE=20
POINT<BR>CLASS<BR>STYLE<BR>SYMBOL 'cline'<BR>size 2<BR>COLOR 245 88=20
128<BR>ANTIALIAS TRUE<BR>END<BR>END<BR>END<BR><BR>END # Map File=20
</FONT></DIV></BODY></HTML>
------=_NextPart_000_015C_01C3B299.B5D261F0--
