[Mapserver-users] GPS Point data output in MapServer
Lowell Filak
lfilak at medinaco.org
Mon Nov 24 12:12:32 EST 2003
Being that your GPS data is already being incorporated into a database
the issue becomes dynamically generating points on a map based on the
database information.
This type of issue comes up frequently and a query of the archives and
wiki should produce at least a few results that should be helpful.
Lowell
The following message was sent by "David Martin" <david at itbeyond.com.au>
on Mon, 24 Nov 2003 17:37:08 +0800.
> Hi,
> I am working on an app at present and I am wanting to integrate external
> GPS data plots and point files into online maps. The data I have as
> input is basically lat/long points and descriptions. I am currently
> writing out a .map file and adding a long list of FEATURE references on
> multi layers. It works fine however I am just wondering if there is a
> more correct or better way to be able to do this on the fly. The data is
> coming from an SQL database and is not in any shape file formats.
> Basically a table with Desc, Lat & Long - this data changes often.
> Any thoughts or ideas much appreciated!
> Regards
> David Martin
> DIRECTOR
> I.T. Beyond Pty Ltd
> Postal: PO BOX 967
> HILLARYS WA 6923
> Ph: (08) 9403 3737
> Mobile: 0417 677 275
> Fax: (08) 9403 3738
> _____
> Check out our websites: www.ExplorOz.com <http://www.exploroz.com/> and
> www.itbeyond.com.au <http://www.itbeyond.com.au/>
