[Mapserver-users] Problem with access jBox's methods from javascripts functions.
    TN Jorge Alberto Arocha Muñoz
    jorge.arocha at armada.mil.co
    Tue Nov 25 12:23:09 PST 2003
I have next problem:
1.  Template:
<html>
<head>
  <script language="javascript" src="/interface_sig/javascript/sig.js"></script>
</head>
<body>
  <img name="zoomin" src="/interface_sig/imagenes/zoomin_nopres.png" onClick="clickboton(this); document.jBox.boxon();">
  <img name="pan" src="/interface_sig/imagenes/pan_nopres.png" onClick="clickboton(this); document.jBox.dragon();">
  <img name="zoomout" src="/interface_sig/imagenes/zoomout_nopres.png" onClick="clickboton(this); document.jBox.boxoff();">
  <img name="medir" src="/interface_sig/imagenes/medir_nopres.png" onClick="clickboton(this); document.jBox.lineon();">
    <form method="GET" name="mapserv" action="/cgi-bin/mapserv">
    <applet codebase="/interface_sig/jBox" code="jBoxPNG.class" width="578" height="305" name="jBox" MAYSCRIPT>
	  <param name="image" value="http://[host][img]">
    </applet>
</body>
</html>
2. File sig.js
	function clickboton(objeto) {
		activo.src = base + activo.name + '_nopres.png';
		activo = objeto;
		objeto.src = base + objeto.name + '_pres.png';
		switch (activo.name) {
			case 	'info'		:
						map_obj.modo = 'nquery';
						break;
			case	'zoomin'	:
						map_obj.modo = 'browse';
						map_obj.zoomdir = '1';
						break;
			case	'pan'		:
						map_obj.zoomdir = '0';
						break;
			case	'zoomout'	:
						map_obj.zoomdir = '-1';
This way all it's Ok, access jBox's methods work fine, but i want to use only function "clickboton()" at event onClick and try:
1.  Supress in the img tag,  jBox method:
 <img name="zoomin" src="/interface_sig/imagenes/zoomin_nopres.png" onClick="clickboton(this)">
2.  Add in file sig.js on function clickboton():
		activo = objeto;
			case 	'info'		:
						break;
			case	'zoomin'	:
						break;
			case	'pan'		:
						break;
			case	'zoomout'	:
With these changes the page dosen't work.  The javascript debugger display this message: Exception ``TypeError: document.jBox.boxon is not a function'' thrown from function clickboton().
I treated other forms:
*  document.applet.jBox.boxon()
*  document.applets[0].boxon()
And nothing to do.
Any idea......
Thanks for your help......
More information about the MapServer-users
