[Mapserver-users] The specified CGI application misbehaved by not returning a complete set of HTTP headers. The headers it did return are:
Martin, Daniel A
Daniel.A.Martin at erac.com
Tue Nov 25 16:14:56 EST 2003
Usually, this happens when you didn't install the dll libraries. The
dll files included in the binary distribution (in the lib directory)
need to be placed in your system path. Typically, they are placed into
C:\Winnt\system32 but they can be placed anywhere in the path.
Since you are using the Oracle distribution, you also need the Oracle
dll libraries in the path as well. These aren't distributed with
MapServer. They come with Oracle.
-Dan
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
> Gautam Ganguly
> Sent: Tuesday, November 25, 2003 1:33 PM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] The specified CGI application
> Hi all,
> I am a newbie to Mapserver and in the process of using
> mapserver ver4.0 for Oracle Spatial on Win2000 server.I
> followed the instruction for installing the server as well as
> the demo app.But when i try to access the map server from my
> browser using: http://localhost/cgi-bin/mapserv.exe , i get
> these error message: CGI Error: The specified CGI application
> My system Setup is: Win2000 Advanced
> IIS : 5.0
> Binary file name from the download site: ms40_gif_oracle.zip
> I followed the install as is given on the site at
> http://mapserver.gis.umn.edu/demo_readme.html.
> I did search
> the mailing list archive for the solution, but didnot find
> any. Before sending these mail i tried the hints provided on
> the mailing list as noted below: A)From command prompt when i
> run mapserv.exe,i get the following
> message:
> C:\Inetpub\cgi-bin>mapserv.exe
> This script can only be used to decode form results and
> should be initiated as a CGI process via a httpd server.
> B)by passing -v parameter i get the following output in the command
> prompt:
> C:\Inetpub\cgi-bin>mapserv.exe -v
> MapServer version 4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ
> SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7
> INPUT=ORACLESPATIAL INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> Any help would be highly appreciated.
> regards,
> Gautam
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
