[Mapserver-users] The specified CGI application misbehaved by
not returning a complete set of HTTP headers. The headers it did return
are:
Swaminathan, Gayathri
gayathri at ou.edu
Tue Nov 25 15:50:01 EST 2003
Gautam,
Did you copy all the default library dlls to somewhere mapserver can find
like C:<windows dir>\system32 directory?
Gayathri
-----Original Message-----
From: Gautam Ganguly [mailto:ggangul at transunion.com]
Sent: Tuesday, November 25, 2003 1:33 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] The specified CGI application misbehaved by not
returning a complete set of HTTP headers. The headers it did return are:
Hi all,
I am a newbie to Mapserver and in the process of using mapserver ver4.0
for Oracle Spatial on Win2000 server.I followed the instruction for
installing the server as well as the demo app.But when i try to access the
map server from my browser using: http://localhost/cgi-bin/mapserv.exe , i
get these error message: CGI Error: The specified CGI application misbehaved
by not returning a complete set of HTTP headers. The headers it did return
are:
My system Setup is: Win2000 Advanced
IIS : 5.0
Binary file name from the download site: ms40_gif_oracle.zip
I followed the install as is given on the site at
http://mapserver.gis.umn.edu/demo_readme.html.
I did search the mailing list archive for the solution, but didnot find
any. Before sending these mail i tried the hints provided on the mailing
list as noted below: A)From command prompt when i run mapserv.exe,i get the
following
message:
C:\Inetpub\cgi-bin>mapserv.exe
This script can only be used to decode form results and
should be initiated as a CGI process via a httpd server.
B)by passing -v parameter i get the following output in the command
prompt:
C:\Inetpub\cgi-bin>mapserv.exe -v
MapServer version 4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7
INPUT=ORACLESPATIAL INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Any help would be highly appreciated.
regards,
Gautam
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
