[Mapserver-users] Graticule problem
Sebastian Albrecht
api at justapi.de
Wed Nov 26 03:06:14 EST 2003
Hi Ann,
I just asked that question two days ago - using a mercator projection.
The problem is the grid's maximum latitude values are -90 and 90. If
you enter those values manually in PROJ4 using your projection you
might see * is returned. I suppose this shall be something like
infinite (-90 and 90 with mercator) or undefined.
I had the same problem with a coastline shapefile that had a line from
-180 -90 to 180 -90 to border the bottom of the Antarctica polygon and
I had the same problem (screenshots http://justapi.de/mapserv). I
solved it by just moving that line to (-180 -89.5) (180 -89.5).
John Novak who developed that GRID feature wrote me yesterday he would
have a look at the problem after Thanksgiving.
Best regards,
Sebastian Albrecht
> I'm having a problem adding a GRID layer to an albers projected map.
> The grid is fine, except that it adds a couple of extra lines which
> intersect at the center of the projection. An example of this is here:
> http://www.etl.noaa.gov/tmp/NEAQS-ITCT106980036229689.png
> Has any seen this or bet yet fixed it?
> Thanks-
> Ann
> The map file has the overall projection:
> EXTENT -4530061.9375 89.6875 3618936.0 713.75 # Albers
> UNITS METERS
> PROJECTION
> "+proj=aea +lat_0=40.0 +lon_0=-40.0 lat_1=29.5 lat_2=45.5 "
> END
> And the GRID layer is:
> LAYER
> NAME "GRID"
> TRANSPARENCY 30
> PROJECTION
> "proj=latlong"
> END
> TYPE LINE
> STATUS DEFAULT
> CLASS
> COLOR 0 0 0
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 0
> OUTLINECOLOR 255 255 255
> END
> END
> GRID
> MINSUBDIVIDE 64
> MAXSUBDIVIDE 64
> MININTERVAL 10
> MAXINTERVAL 10
> LABELFORMAT "DDMM"
> END
> END
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
