[Mapserver-users] Graticule problem
Ann Keane
Ann.Keane at noaa.gov
Tue Nov 25 19:28:31 EST 2003
I'm having a problem adding a GRID layer to an albers projected map.
The grid is fine, except that it adds a couple of extra lines which
intersect at the center of the projection. An example of this is here:
http://www.etl.noaa.gov/tmp/NEAQS-ITCT106980036229689.png
Has any seen this or bet yet fixed it?
Thanks-
Ann
The map file has the overall projection:
EXTENT -4530061.9375 89.6875 3618936.0 713.75 # Albers
UNITS METERS
PROJECTION
"+proj=aea +lat_0=40.0 +lon_0=-40.0 lat_1=29.5 lat_2=45.5 "
END
And the GRID layer is:
LAYER
NAME "GRID"
TRANSPARENCY 30
PROJECTION
"proj=latlong"
END
TYPE LINE
STATUS DEFAULT
CLASS
COLOR 0 0 0
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 0
OUTLINECOLOR 255 255 255
END
END
GRID
MINSUBDIVIDE 64
MAXSUBDIVIDE 64
MININTERVAL 10
MAXINTERVAL 10
LABELFORMAT "DDMM"
END
END
