[Mapserver-users] MrSID
Aaron D. Hunt
hunt at zedxinc.com
Wed Nov 26 08:59:32 EST 2003
Oliver
Do You know where the DSDK can be gotten from. I was on Lizardtech site and
could not find any thing on it, and I email them and have not gotten any
replay.
Aaron
----- Original Message -----
To: "Matthias Schulz" <schulz at gaf.de>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, November 26, 2003 5:33 AM
Subject: Re: [Mapserver-users] MrSID
> Matthias,
> MrSID is supported through GDAL. This is a new devlopment. Here is what
> Frank has posted on this list (2003/22/08):
> "This is a new development. MrSID support was implemented by Andrey
> Kiselev in the last 2 months under a contract from i-Cubed specifically
> to allow use of MrSID in MapServer.
> On Linux (and presumably other Unix platforms) you would configure with
> the --with-mrsid=(dir) switch. The MrSID DSDK on Linux requires a very
> specific version of gcc, so everything else (GDAL, and MapServer) will
> need to be compiled with the same version.
> On Windows set the MRSID_HOME variable in the GDAL nmake.opt file.
> Some additional details are available in the GDAL "building from source"
> page, and in MrSID format page itself. Followups on build problems
> should go to the gdal-dev list.
> I would add that due to the licensing of the MrSID libraries, I am
> unable to redistribute binaries of GDAL utilities or MapServer with
> MrSID support. You will need to license the DSDK from Lizardtech and
> build GDAL yourself. "
> best regards
> Oliver
> Matthias Schulz wrote:
> > As I have seen in the archive there are currently no plans to support
> > MrSID data. I am wondering what would be the programming effort for this
> > integration if one would use the sdk from MrSID. Could anyone give me a
> > rough idea of the effort or the aproach?
> > Thanks,
> > Matthias
> > Matthias Schulz
> > GAF AG Arnulfstr. 197 80634 Muenchen Germany
> > tel.: +49 (0)89 121528-28 fax: +49 (0)89 121528-79
> > mailto:schulz at gaf.de http://www.gaf.de
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Dipl.-Geogr. Oliver Wesp
> Gesellschaft fu"r geografische Datenverarbeitung
> Binger Strasse 49-51
> D-55218 Ingelheim
> fon: +49 6132 714818
> fax: +49 6132 714828
> http: www.gdv.com
