[Mapserver-users] PHP/Mapscript Newbie needs help, Segmentation faults and blank images, nothing in logs
Ed Martin
edman007x at mac.com
Wed Nov 26 21:01:54 EST 2003
ok this is my first time using php/mapscript so i'm starting off simple
just draw the map, scale bar and reference image, i'm using the itasca
mapserver demo and have commented out all layers but one, i have also
changed all the images in it to png's from gifs so it would work with
gd and i have changed the map file accordingly, so i made a few simple
scripts based on the test draw thing included with mapscript and they
should out put the images
so here are the php files i have
require_once ('../inc/conf.inc.php');//get config
//load mapscript
dl("php_mapscript.so");
header("Content-type: image/jpeg");
//start map
$map = ms_newMapObj("itasca/demo.map");
$img = $map->draw();
$img->saveImage('');
in my my browser the image shows up fine, but when run from the command
line i get the headers, garbled text (what i expect), followed by
Segmentation fault, what is that
then i have this one to make the reference image
//load mapscript
// start map
$img = $map->drawReferenceMap();
in my browser if outputs a yellow image (yellow is what is set in the
.map file), but there is no picture of anything, just yellow, shouldn't
it be based on the reference image referred to in the .map file, when
run in the command line i get headers and garbled text, exactly what i
expect
then i have this to draw the scale bar
//load mapscript
//start map
$img = $map->drawScaleBar();
in my browser i get a blank page (not a white image) and when run in
the command line i get the headers followed by "Segmentation fault"
what is this Segmentation fault and what is causing it, all the scripts
are the same except for one function, i have display errors on and log
them, tried disabling the headers, and the errors are all logged and
error reporting is set to E_ALL and i get no errors anywhere
and why isn't the reference map showing anything but the color
specified in the .map file, there are no gifs and gd supports png's,
everything is being output as jpegs
i am using php 4.3.4 as a CGI with apache 2.0.48 on slackware linux 9.0
any help would be great
Thanks in Advanced!
