[mapserver-users] line width
Mike Leahy
mgleahy at fes.uwaterloo.ca
Thu Nov 27 21:36:49 EST 2003
Hello group,
I'm also trying to see if I can change line widths in maps generated by
MapServer. I did a bit of a search and this old post is the only close result
I found. I've looked through the MapFile documention MapServer and the object
structure for PHP_MapScript which I am using...and I can't find anything that
talks about setting line width - I would have guessed that this would be kind
of a standard option for most mapping tools, so I'm hoping I've just missed
something somewhere.
Does anyone have any suggestions?
Thanks,
Mike
John Hagstrand wrote:
Hi Stephen,
Thanks for responding. Yes I can post the map file. It is included below.
John
At 09:04 AM 4/17/2002, you wrote:
John,
can you post the section of your map file that controls the shapefiles
in question. Typically, it is the SIZE parameter often used in
conjunction with SYMBOL 'circle'
-Steve
> Hello,
> How do I specify line width for line shape files? Mine are coming up two
> pixels wide, and I want it to be one.
> Thanks
> John
# Start of map file
NAME DEMO
STATUS ON
SIZE 600 260
#EXTENT -88.128 42.436 -87.991 42.497
UNITS dd
SHAPEPATH "data"
IMAGECOLOR 255 255 255
# Start of web interface definition (including WMS enabling metadata)
WEB
HEADER demo_header.html
TEMPLATE demo.html
FOOTER demo_footer.html
MINSCALE 1000
MAXSCALE 1550000
IMAGEPATH "set in demo_init.html"
IMAGEURL "set in demo_init.html"
METADATA
WMS_TITLE "UMN MapServer Itasca Demo"
WMS_ABSTRACT "This is the UMN MapServer demonstration application for Itasca
County located in north central Minnesota."
WMS_ACCESSCONSTRAINTS none
# change this value to match your setup
WMS_ONLINERESOURCE "http://localhost/itasca/demo_init.html";
WMS_SRS "EPSG:26915"
END
END
QUERYMAP
SIZE 200 200
STATUS ON
STYLE HILITE
COLOR 255 0 0
END
# Start of layer definitions
LAYER
NAME aerial
TYPE RASTER
STATUS OFF
DATA aerial00.tif
CLASS
NAME 'aerial'
COLOR 49 117 185
END
END # aerial
LAYER
NAME lakes
TYPE POLYGON
STATUS OFF
DATA wbd17097
CLASS
NAME 'Lakes'
COLOR 49 117 185
END
TOLERANCE 3
END # lakes
LAYER
NAME railroads
TYPE LINE
STATUS OFF
DATA lnb17097
CLASS
NAME 'Railroads'
COLOR 0 0 0
END
TOLERANCE 3
END # railroads
LAYER
NAME streets
TYPE LINE
STATUS OFF
DATA str17097
CLASS
NAME 'Streets'
COLOR 0 255 0
SIZE 0
MAXSIZE 1
END
TOLERANCE 5
END # streets
LAYER
NAME streams
TYPE LINE
STATUS OFF
DATA lnh17097
CLASS
NAME 'Streams'
COLOR 0 0 255
END
TOLERANCE 3
END # Streams
END # Map File
John Hagstrand
Interage Research, Inc.
847 838 5371
Software Development Consulting for Internet Archive Retrieval
We help archives make knowledge accessible, useful, and relevant for everyone.
http://www.interageresearch.com
This mail sent through www.mywaterloo.ca
