[Mapserver-users] 4.0 mapscript on freebsd 4.4
Benjamin Thelen CCGIS
thelen at ccgis.de
Mon Sep 1 15:15:09 EDT 2003
-------- Received an error from umn-mapserver mailman-2.0.13 ----
-------- This mail could not be delivered! -------------
-------- 2nd attempt -----------
Hi Joe,
I exactly have the same error code on FreeBSD 4.7 and FreeBSD 4.8!
As you wrote with mapscript 3.6.5 and 3.6.5 it was possible to compile
after a few changes within mapscript Makefile:
Change:
CC= cc to CC= gcc
LD= cc -Wl -Wl, to LD= gcc -Wl -Wl,-share
and
-I$(PHP_SRC_DIR)/dl to -I$(PHP_SRC_DIR)/ext
This does not work anymore!!
Here is some mapserver related software listed, I've installed!
GD 2.0.15
php 4.3.3
gdal 1.1.8
pg-sql 7.3.2
curl 7.10.5
proj 4.4.5
gcc-3.2.3
gmake 3.80
Sorry, I have no idea what to do, either! :-(
What I found out is, that in php_mapscript_util.h are two lines #Include
"php.h" and #Include "php_globals.h". Both files are definitely within the
source tree of php, given within the mapserver configure option
--with-php=PATH-TO-SOURCE-TREE. What I really do not understand is, why
the file maperror.h cannot be found. It is within the source tree of
mapserver 4.0 I'm actually building?! Additionally I do not understand the
last line of the error code, as there is no #Include "maperror.h" within
php_mapscript_util.h. I found that in php_mapscript_util.c on line 101.
Perhaps the code is making use of a variable or something like that, which
isn't provide on FreeBSD?
Well, I don't know how all that works!
Regards,
Benjamin
> Has anyone tried to compile mapserver 4.0 with mapscript on freebsd yet?
> I'm trying on freebsd 4.4, but the php mapscript Makefile seems to be
> erroring during compile - much like the old version of mapserver did.
> Except this time the Makefile is different, and the old fixes that worked
> in
> 3.6 don't work in 4.0.
> Here's the error code:
> gcc -fPIC -02 -Wall -DCOMPILE_DL=1 -DPHP4 -c php_mapscript_util.c
> In file included from php_mapscript_util.c:101:
> php_mapscript_util.h:58: php.h: No such file or directory
> php_mapscript_util.h:59: php_globals.h: No such file or directory
> php_mapscript_util.h:102: maperror.h: No such file or directory
> *** Error code 1
> Stop in /usr/home/joe/mapserver40/mapscript/php3.
> *** Error code 1
> Here's part of the Makefile (where the error might be):
> CC = gcc -fPIC
> LD = c++ -shared
> CFLAGS = -02 -Wall -DCOMPILE_DL=1 -DPHP4
> RUNPATHS=
> What do I need to change?
> Joe
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
