[Mapserver-users] exporting dxf file using php/mapscript
Attila Csipa
plists at prometheus.org.yu
Wed Sep 3 06:05:48 EDT 2003
On Wednesday 03 September 2003 01:54, woodbri at swoodbridge.com wrote:
> Well, aside from various difficulties you might face with respect to
> handling data that dxf may not handle well, like image data, I think
> the best way to do this would be to write an OUTFORMAT driver for DXF
> format. I think you be able to use the Flash driver as a start point
Actually there already is an (untested and just as undocumented) DXF
OUTPUTFORMAT, not for the faint at heart. You can try it out if you have a v4
mapserver or newer cvs code. Do everything as usual, just drop the following
in your mapfile to generate dxf-s instead of images:
OUTPUTFORMAT
NAME imagemap
MIMETYPE "text/plain"
DRIVER imagemap
EXTENSION dxf
FORMATOPTION DXF=ON
END
