[Mapserver-users] Reading DWG
Stephen Clark
stephen.clark at focus.ca
Thu Sep 4 14:11:31 EDT 2003
Frank and others,
My two cents:
I have tried using the opendwg software with not much luck.
I am now interested in FME from Safe software. www.safe.com
It has scripting abilities via a perl system command that can convert DWG to
SHP, vice versa and many more tricks for handling spatial data.
My plans with DWG files are to automate the viewing of many of my DWG files
on top of the SHP files I already have.
Stephen
----- Original Message -----
To: "Ben Lewis" <blewis at atsincorp.com>
Cc: "mapserver-users" <mapserver-users at lists.gis.umn.edu>
Sent: Thursday, September 04, 2003 10:13 AM
Subject: Re: [Mapserver-users] Reading DWG
> Ben Lewis wrote:
> > Does anyone know of efforts to get Mapserver read AutoCAD DWG files?
> > (I am aware of a group, OpenDWG http://www.opendwg.org/ that has created
a DWG toolkit and some specs.)
> > - Ben
> Ben,
> I have been intended to implement OGR support for DWG (and DXF) via the
> OpenDWG toolkit at some point but haven't gotten to it yet. I have a
couple
> clients who have expressed some interest, so there might be work on this
in
> coming months but nothing is certain.
> One issue with doing this is that DWG and DXF files are "graphically
rich".
> Getting the line work out and accessable in MapServer wouldn't be too
hard.
> Getting a DWG file to look the same when rendered in MapServer as it looks
> in AutoCAD is worlds harder.
> With the DGN format some graphical information was captured and passed
through
> to MapServer and with STYLEITEM AUTO you would get something that look
similar
> to what the picture looked like in Microstation. I would imagine this
would
> also be done for DWG but it is important to realize that even if a
moderate
> effort is made to support DWG it will come with many limitations and
caveats.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
