[Mapserver-users] PostGIS/Mapserv problem with type MULTIPOLYGON.
Thierry Lombardot
tlombard at mpi-bremen.de
Tue Sep 9 10:45:38 EDT 2003
Thank you Vinko,
Here is a part of my map file:
LAYER
NAME Lakes_quality
CONNECTIONTYPE postgis
CONNECTION "user=mapserver password='XXX' dbname=mm host=localhost"
DATA "the_geom from lake_quality_po"
# FILTER "_labelid < 1500"
# DEBUG
TYPE POLYGON
STATUS ON
CLASS
NAME 'Lakes_quality'
# TEMPLATE "lakespy2.html"
# EXPRESSION ([_polygonid] <= 500)
COLOR 0 0 255
# SYMBOL "disk"
# SIZE 2
END
# HEADER "lakespy2_header.html"
# FOOTER "lakespy2_footer.html"
# TOLERANCE 3
# DUMP TRUE # allow GML export
# METADATA
# WMS_TITLE "Water Bodies 2"
# WMS_ABSTRACT "XX"
# WMS_SRS "XX"
# END
END # Layer Lakes_quality
and my postgres structure (from a shp2sql import):
table lake_quality_po
***columns:
gid
id
ims_id
lake
geo_reg
gems_name
area
volume
max_depth
residence
tds
na_plus
k_plus
ca_plus_plus
mg_plus_plus
so4_minus_minus
cl_minus
hco3_minus
sio2
po4_p
no3_n
the_geom
***first line:
0
129
12
Aral Sea
Europe
Aral
64100
1020
68
20
10500
-9999
-9999
-9999
-9999
-9999
-9999
-9999
-9999
-9999
-9999
SRID=-1;MULTIPOLYGON(((60.903450012207 46.1099090...
Do you see someting wrong?
Thx
Thierry.
Vinko Vrsalovic wrote:
> On Tue, Sep 09, 2003 at 02:17:01PM +0200, Thierry Lombardot wrote:
>>Dear Mailling list,
>>I get a problem with PostGIS/Mapserv:
>>If a geometry column of a table contains a type "MULTIPOLYGON", I can't
>>draw it with mapserv. I tried the types: LINE or POLYGON within my map
>>file, but the same error comes up in my apache error_log:
>>[Tue Sep 9 13:56:22 2003] [error] [client 127.0.0.1] Premature end of
>>script headers: /srv/www/cgi-bin/mapserver/mapserver-4.0/mapserv
>>Do I have to convert multipolygons is separated polygons? Is there a
>>PostGIS function to do that?
> Are you sure that's the reason? It would help if you send us the mapfile
> with the query you're using and how's the data structured on the DB.
> Maybe you're missing selecting some data needed by the layer definition
> (that has been my experience with that error, it always is something
> wrong/missing in the query).
> I've drawn multipolygon layers thousands of times with 4.0 and PostGIS
> CVS :-)
> Good luck,
