[Mapserver-users] Draw line in a map file
Eric Bridger
eric at gomoos.org
Wed Sep 10 10:19:07 EDT 2003
O.K. I ran a quick test. You also need a CLASS in your layer in order
to set the features color:
So try:
LAYER
NAME "pin"
CLASS
COLOR 255 0 0
END
FEATURE
END
END
You might also try TRANSFORM FALSE since
POINTS 1 1 50 50 50 1 1 1 END
looks like pixel values to me.
Eric
On Wed, 2003-09-10 at 17:31, rajsalem at optonline.net wrote:
> Hi Eric,
> Thanks for your reply. i tried the feature object in the map file, but i am not getting the line drawn. here is the map file i am using.
> MAP
> NAME "test"
> EXTENT 100 100 500 500
> SIZE 400 500
> IMAGECOLOR 102 102 255
> TRANSPARENT OFF
> UNITS METERS
> IMAGETYPE GIF
> LAYER
> NAME "pin"
> STATUS DEFAULT
> TYPE LINE
> TRANSFORM TRUE
> FEATURE
> TEXT "ptdrw"
> POINTS
> 1 1 50 50 1 50 1 1
> END
> END
> END
> # LAYER
> END
> any changes needs to be done.
> Raj
> ----- Original Message -----
> From: Eric Bridger <eric at gomoos.org>
> Date: Wednesday, September 10, 2003 8:44 am
> Subject: Re: [Mapserver-users] Draw line in a map file
> > You need a FEATURE object in your map file. See this:
> > http://mapserver.gis.umn.edu/doc36/mapfile-reference.html#feature
> > Sorry I can't recall exactly how it is used. I believe the
> > FEATURE must
> > be part of a LAYER. Your POINTS can be either pixels or lat/lon by
> > setting TRANSFORM FALSE (pixels) or TRUE (lat/lon)
> > Eric
> > On Wed, 2003-09-10 at 15:06, rajsalem at optonline.net wrote:
> > > hello mapserver-users,
> > > How do i draw a line from a map file without having any
> > shapefiles defined in the layer. Can i draw a lines or points in
> > a map file and just call the map from mapserver.
> > > Thanks,
> > > Raj.
> > > _______________________________________________
> > > Mapserver-users mailing list
> > > Mapserver-users at lists.gis.umn.edu
> > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
