[Mapserver-users] seg fault
Krung Saengpole
krung at cad.go.th
Thu Sep 11 16:50:01 EDT 2003
I think that's not the case. I used to use 76 layers with perl mapscript, it worked.
Krung
>> Aha! I've narrowed down the problem further. It seems that I'm only
>> able to open 2 shapefiles in a single instance of a perl program
>> running. As soon as I try and open a 3rd, boom! Seg fault.
>> Nick
>Um... I can open 3 shapefiles using PHP MapScript (4.0 and 3.6) without
>any problem. Perhaps it's a Perl-specific issue, or it's realted to the
>order in which your script does things?
>If you have a way to reproduce this, then you should probably file this
>in bugzilla, with sample data and script to reproduce, MapServer
>version, OS, etc.
>Daniel
>> At 02:31 PM 9/11/2003 -0400, you wrote:
>>> Nick Petersen-Bergeron wrote:
>>>> To clarify, the file DOES already exist, and seems to be a valid
>>>> shapefile.
>>> Assuming that you are able to read the shapefile using something like
>>> shapelib's shpdump utility, My next suggestion would be to try to
>>> isolate the exact lines that cause the problem. Does the following
>>> also seg fault?
>>> #!/usr/bin/perl
>>> use mapscript;
>>> use XBase;
>>> my $SFile = "/home/httpd/cgi-bin/dm/shapes/S941604";
>>> my $SShapeFile = new shapefileObj($SFile,-1);
>>> Daniel
>>> Daniel Morissette morissette at dmsolutions.ca
>>> DM Solutions Group http://www.dmsolutions.ca/
>> System Administrator
>> ZedX Inc.
>> 369 Rolling Ridge Drive
>> Bellefonte, PA. 16823
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
