[Mapserver-users] PHP/MapScript question: How to return values when map is clicked?
Krung Saengpole
krung at cad.go.th
Thu Sep 11 17:58:51 EDT 2003
use queryByPoint(...). But you have to convert point in image to georef and make a pointObj from it. e.g.
$point=ms_newPointObj();
$point->setXY(x_coordinate, y_coordinate);
if (@$layer->queryByPoint($point,MS_SINGLE,0) == MS_SUCCESS) {
$result = $layer->getResult(0);
$index = $result->shapeindex+1;
$dbf = dbase_open(DBF_FILE,0);
$arr = dbase_get_record($dbf,$index);
HTH
Krung
---------- Original Message ----------------------------------
Date: Thu, 11 Sep 2003 13:05:26 -0700 (PDT)
>Hello,
>I am displaying a shapefile that contains states as a GIF. I am not using javascript at all. When the user clicks on the map, I want to return the name of the state that was clicked, and some other information that is in the dbf file. How do I do this? I can get the x,y coords by having the GIF set as an input type. I assume I will have to convert them to georef coords. But I am unsure of what 'function' to use to get those results. Any help would be greatly appreciated.
>Cheers
>Do you Yahoo!?
>Yahoo! SiteBuilder - Free, easy-to-use web site design software
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
