[Mapserver-users] TEXT expression and MAPMYGIS
woodbri at swoodbridge.com
Fri Sep 12 07:52:12 EDT 2003
Alan,
Try TEXT ([f_ID],[f_NEIGHBORHOOD]) instead of
TEXT "([f_ID],[f_NEIGHBORHOOD])" so the string is evaluated.
-Steve
On 12 Sep 2003 at 1:49, Alan Steremberg wrote:
> Hi,
> I built a simple database with points, and a bunch of fields that will
> eventually have weather data. (If you go to:
> http://www.wunderground.com/US/CA/San_Francisco.html scroll to the
> bottom and click on the MSN map, you will see what I am trying to
> build)
> I would like to pull two fields out of the database, like:
> f_ID and f_NEIGHBORHOOD
> If i put it in the LABELITEM as above, it works and I get lots of
> weather stations. If i try to create the expression below, it just
> prints the text ([f_ID],[f_NEIGHBORHOOD]) on the map without
> evaluating it. The other thing I don't understand is that it has to
> be TYPE ANNOTATION not TYPE POINT. what am I doing wrong?
> LAYER
> CONNECTIONTYPE mygis
> NAME "pws"
> CONNECTION "g7:wui:Phishy:geodata:num"
> DATA "geometry from pws feature, pws_num geometry"
> STATUS DEFAULT
> #TYPE POINT
> TYPE ANNOTATION
> LABELITEM "f_NEIGHBORHOOD"
> #LABELITEM "f_ID"
> LABELCACHE TRUE
> CLASS
> NAME "Weather Station"
> # TEXT "([f_ID],[f_NEIGHBORHOOD])"
> #TEXT "(A,B)"
> SYMBOL "marker"
> COLOR 0 0 0
> LABEL
> TYPE TRUETYPE
> FONT "verdana-bold"
> SIZE 8
> #POSITION UC
> POSITION AUTO
> OFFSET 0 10
> BUFFER 2
> COLOR 200 0 0
> OUTLINECOLOR 230 230 230
> FORCE TRUE
> END
> END
> END
> Thanks!
> Alan
> Alan Steremberg
> 415-543-5021 x 103
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
