[Mapserver-users] Please help with Querying a Map (Postgis-Layer)
Antje Rosse
antje.rosse at itc-halle.de
Fri Sep 12 07:37:05 EDT 2003
The Error:
<!-- MapServer version 3.6.6 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=TTF INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS
INPUT=SHAPEFILE --> <BODY BGCOLOR="#FFFFFF">
msPOSTGISLayerGetShape(): Query error. Error executing POSTGIS SQL
statement (in FETCH ALL): EXPLAIN VERBOSE SELECT * FROM punkte_tabelle
Error with POSTGIS data variable. You specified ''.<br> Standard ways of
specifiying are : <br>
(1) 'geometry_column from geometry_table' <br>
(2) 'geometry_column from (<sub query>) as foo using unique
<column name> using SRID=<srid#>' <br><br>
Make sure you put in the 'using unique <column name>' and 'using
SRID=#' clauses in.
Table punkte_tabelle with index punkte_tabelle_oid_idx (oid).
My Layer-Definition:
LAYER
CONNECTIONTYPE postgis
NAME pers_punkte
CONNECTION "user=postgres password=ppp dbname=test_db"
DATA 'the_geom from punkte_tabelle using unique oid using SRID=-1'
TYPE POINT
STATUS ON
HEADER
"/srv/www/htdocs/mapserver/test_mapplet/java/mapplet/halgis_pers_pkt_hea
der.html"
FOOTER "halgis_alle_footer.html"
CLASS
NAME 'Punkte'
TEMPLATE
"/srv/www/htdocs/mapserver/test_mapplet/java/mapplet/halgis_pers_pkt.htm
l"
OUTLINECOLOR 0 0 220
COLOR 0 0 220
SYMBOL 'circle'
size 12
END
END
Thanks very much!
mfg. Antje Rosse
IT-Consult Halle GmbH
Bornknechtstraße 5, 06108 Halle (Saale)
Sitz: Große Nikolaistr. 8
Tel.: +49 345 221 4227, Fax: +49 345 221 4236
Funk: +49 160 715 4526
http://www.itc-halle.de
