[Mapserver-users] no labels on dynamic layer
Daniel Morissette
morissette at dmsolutions.ca
Mon Sep 15 10:17:48 EDT 2003
Frieso ter Haseborg wrote:
> drawLabelCache works - at least for the points. But there are still no
> annotations for the lines. Is there an extra operation for the
> line-layer required?
It should be the same for line or points AFAIK, but as usual there is
always the possibility of a bug. The first thing to do would be to make
sure that your layer and label definition are correct, and if they are
then perhaps submit a bug in bugzilla with a small test script that
demonstrates the problem.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
