[Mapserver-users] Compile Issue - Libiconv
Lowell Filak
lfilak at medinaco.org
Fri Sep 12 08:47:51 EDT 2003
It may just be that libiconv.so.2 is on the system but the mapserv
executable cannot locate it.
Take a look at at the different options in the following link for
checking what libraries mapserv was compiled against and depends on and
also how the path to those libaries can be set.
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PerlMapScriptDebugging
HTH
Lowell
The following message was sent by "Mark Rodrigo" <mark at markrodrigo.com>
on Thu, 11 Sep 2003 15:50:00 -0700.
> I've been doing the rounds for sure with the compiling process. RH 8 w
> Mapserver
> 4.x I've got the following error in my Apache error log:
> /usr/local/apache2/cgi-bin/mapserv: error while loading shared libraries:
> libiconv.so.2: cannot open shared object file: No such file or directory
> when I try http://localhost/cgi-bin/mapserv I get:
> "Internal Server Error
> The server encountered an internal error or misconfiguration and was
unable
> to
> complete your request.
> Please contact the server administrator, you at your.address and inform
them of
> the
> time the error occurred, and anything you might have done that may have
> caused
> the error.
> More information about this error may be available in the server error
log.
> Apache/2.0.47 (Unix) Server at localhost Port 80"
> The properties of the file are:
> 443.1 k binary program. The permissions are wide open.
> Any ideas?
> Thanks
> Mark
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
