[Mapserver-users] Ccoordinate/projection display problem?
Gerry Creager N5JXS
gerry.creager at tamu.edu
Sat Sep 13 12:14:36 EDT 2003
I've been swamped, and consequently lost some of this thread. I'm
*still* haveing projection problems, so I'll ask again. Maybe I'll
understand what's going on...
If, in my mapfile I want to have the final projection in Lambert
Conformal Conic, but all of my data are Lat/Lon unprojected, then, the
PROJECTION section of the top layer is LCC, while the projection info in
all the layers would be LAT-LON? Or is this inverted?
Confusedly yours,
Gerry
Ed McNierney wrote:
> Ann -
> Actually, the EPSG code IS a complete description - but you were using
> the same code for all your layers in your original map file.
> The EPSG code is, I think, somewhat preferable IF you are using a
> standard projection. The downside is that it's a little cryptic (a MAP
> file comment would help) but the upside is that it's much harder to make
> typos, and much easier to ensure that two projections that should be the
> same ARE the same.
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA 01863
> Phone: (978) 251-4242 Fax: (978) 251-1396
> ed at topozone.com
> -----Original Message-----
> From: Ann Keane [mailto:Ann.Keane at noaa.gov]
> Sent: Friday, September 12, 2003 7:31 PM
> To: Frank Warmerdam
> Cc: mapserver-users at lists.gis.umn.edu; Ed McNierney
> Subject: Re: [Mapserver-users] Ccoordinate/projection display problem?
> Ed and Frank-
> Thank you both. You were correct in that I was not completly describing
> the coordinates and projection. This is all well beyond what I think I
> know about cartography, so I thought the epsg code was the complete
> description. listgeo -proj4 will be invaluable to me. We're just
> getting started with the project so I've been using the full data files.
> The suggestions about reprojecting will be very helpful when we start
> running the system operationally.
> The resulting projection was:
> PROJECTION
> "+proj=laea +lat_0=45.000000000 +lon_0=-100.000000000 +x_0=0.000
> +y_0=0.000 +ellps=WGS84 +units=m"
> END
> -Ann
> Frank Warmerdam wrote:
>>If you have
>>listgeo handy you might try running "listgeo -proj4 shdrlfi0201.tif"
> to
>>see what it things is a good "PROJ.4 string" representing the
> coordinate
>>system of the file in question.
>>I would guess you will want something like:
>>PROJECTION
>> "+proj=laea +lat_0=45 +lon_0=-100 +datum=WGS84"
>>END
>>You can test convert points using the PROJ commandline tools something
> like
>>this:
>>warmerda at gdal2200[29]% cs2cs +proj=laea +lat_0=45 +lon_0=-100
>>+datum=WGS84 +to +proj=latlong +datum=WGS84
>> -6086629. 4488761 (input)
>> 156d3'31.097"E 37d45'55.65"N 0.000 (output)
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Gerry Creager -- gerry.creager at tamu.edu
Texas Mesonet -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
Page: 979.228.0173
Office: 903A Eller Bldg, TAMU, College Station, TX 77843
