[Mapserver-users] PHP/MapScript question: How to return values when map is clicked?
Krung Saengpole
krung at cad.go.th
Sat Sep 13 17:56:44 EDT 2003
I'm not sure with getLayerByName. Try quote name in map file. eg.
LAYER
NAME "state"
getLayer() take parameter as
$layer=$myMap->getLayer(layer_index);
Your warning stated that it couldn't find the point you clicked. You can avoid this message by prefixing the function with '@' (PHP aspect) as
@$myMap->queryByPoint(...);
What is your layer's type in map file? It should be POLYGON if you want to click inside its boundary.
HTH
Krung.
---------- Original Message ----------------------------------
Date: Fri, 12 Sep 2003 06:46:37 -0700 (PDT)
>Thanks, that and the examples linked to helped. However, I am running into an error wen I use getLayer or getLayerByName. If I use getLayerByName it tells me it failed (getLayerByName failed for : state)
>I have checked my .map file, and in my .map fil it is indeed called state
>LAYER
> NAME state
>However if I use $layer = $myMap->getLayer, I get the following error
>Warning: [MapServer Error]: msQueryByPoint(): No matching record(s) found.
>Yet I clicked in a state, so I would assume it would have to return the statename (and everything else in the dbf file) to me.
>I wonder what is going on.
>Thankyou
>Har
