[Mapserver-users] Nothing raster (tiff) comes out
Vincent Schut
schut at sarvision.com
Tue Sep 16 03:20:50 EDT 2003
Hi Ayrat,
seems your worldfile is wrong. Description of a worlfile:
pixel x size
rotation about the y axis
rotation about the x axis
- pixel y size
x of upper left pixel
y of upper left pixel
So your worldfile should probably be:
1 (size of 1 pixel is 1 extent unit)
0.0 (no rotation)
0.0 (no rotation)
-1 (size of 1 pixel in y direction)
1 (upper left x coordinate)
1 (upper left y coordinate)
Also, if you use the mapserver cgi interface, don't forget to explicitly ask for the layers to be drawn if you have their status to 'on' (...&layer=<name>&...). Or set status to 'default', then they will get rendered anyways.
Cheers,
Vincent.
On 11:08 Tue 16 Sep , Ayrat wrote:
> Hi all!
> Raster map don't out.
> MS 3.6.6 (Win) and support Tiff (Input tiff)
> but I see white map.
> Along left edge appear gray gradient bands.
> image mode: indexed color.
> Driver: GTiff/GeoTIFF
> Size is 600, 600
> Coordinate System is `'
> Corner Coordinates:
> Upper Left ( 0.0, 0.0)
> Lower Left ( 0.0, 600.0)
> Upper Right ( 600.0, 0.0)
> Lower Right ( 600.0, 600.0)
> Center ( 300.0, 300.0)
> Band 1 Block=600x13 Type=Byte, ColorInterp=Palette
> Color Table (RGB with 256 entries)
> ets.
> [my map file]
> NAME DEMO
> STATUS ON
> SIZE 600 600
> EXTENT 1 1 600 600
> UNITS METERS
> SHAPEPATH "data"
> IMAGECOLOR 255 255 255
> FONTSET fonts/fonts.list
> LAYER
> NAME "rmap"
> DATA "map.tif"
> TYPE RASTER
> STATUS ON
> END
> END
> [Map File]
> Raster howto is saw. Nothing.:(
> world file is wrong? 600
> 0.0000000000
> 0.0000000000
> -600
> 300
> 300
> extentions "wld".
> Can anybody tell what is the problem?
> Thanks and cheers
> Ayrat mailto:Ayrat at ieie.nsc.ru
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
