[Mapserver-users] Nothing raster (tiff) comes out
Ayrat
Ayrat at ieie.nsc.ru
Tue Sep 16 05:51:06 EDT 2003
Hi Vincent.
Problem solved.
Yes, it is. The worldfile is wrong, as you noted.
I downloaded MapLab from
http://www2.dmsolutions.ca/webtools/maplab/maplab_dl.phtml .
In tutorial (maplab) have map file with raster layer.
Replace their image. And ok!!! Finally!!!
Status my layer is "on". Tried "default".
But now OK!!!
Thank you very much!!!
> seems your worldfile is wrong. Description of a worlfile:
> pixel x size
> rotation about the y axis
> rotation about the x axis
> - pixel y size
> x of upper left pixel
> y of upper left pixel
> Also, if you use the mapserver cgi interface, don't forget to explicitly ask for the layers to be
> drawn if you have their status to 'on' (...&layer=<name>&...). Or set status to 'default', then
> they will get rendered anyways.
> Cheers,
> Vincent.
Cheers,
Ayrat mailto:Ayrat at ieie.nsc.ru
