[Mapserver-users] Raster and tileindex
flavio.dalpozzo at procempa.com.br
Wed Sep 17 14:46:35 EDT 2003
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_000_01C37D4C.052B34D0
Content-Type: multipart/alternative;
boundary="----_=_NextPart_001_01C37D4C.052B34D0"
------_=_NextPart_001_01C37D4C.052B34D0
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Please all!
=20
I have this .map:
# Layer para as fotos a=E9reas
LAYER
NAME grade
TYPE line
STATUS DEFAULT
DATA grade5m
# CLASSITEM "TIPO"
TRANSPARENCY 100
CLASS
# EXPRESSION "0"
COLOR 255 255 255
OUTLINECOLOR 0 0 0
END
END
# Fotos A=E9reas
LAYER
NAME "hpool"
STATUS ON
TILEINDEX "grade5m.shp"
TILEITEM "LOCATION"
TYPE RASTER
END
END
when I execute I receive this message:
=20
loadForm(): Web application error. Not enough arguments for imgxy.=20
=20
thanks
=20
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">
<STYLE>BODY {
COLOR: #000000; FONT-FAMILY: "Arial"; FONT-SIZE: 12pt; MARGIN-BOTTOM: =
0em; MARGIN-TOP: 0em
P.msoNormal {
LI.msoNormal {
PRE {
BLOCKQUOTE {
A {
MENU {
DD {
UL {
DT {
DIR {
ADDRESS {
H1 {
H2 {
H3 {
H4 {
H5 {
H6 {
HR {
</STYLE>
<META content=3D"MSHTML 5.00.2920.0" name=3DGENERATOR></HEAD>
<BODY background=3Dcid:978184218 at 17092003-35da>
<DIV><FONT size=3D5><SPAN class=3D978184218-17092003>Please =
all!</SPAN></FONT></DIV>
<DIV><SPAN class=3D978184218-17092003></SPAN> </DIV>
<DIV><SPAN class=3D978184218-17092003><FONT size=3D5>I have this=20
.map</FONT>:</SPAN></DIV>
<DIV><SPAN class=3D978184218-17092003><FONT size=3D1>
<P><SPAN class=3D978184218-17092003><FONT=20
size=3D3>....................</FONT></SPAN></P>
<P><SPAN class=3D978184218-17092003></SPAN><BR># Layer para as fotos=20
a=E9reas<BR>LAYER<BR>NAME grade<BR>TYPE line<BR>STATUS DEFAULT<BR>DATA=20
grade5m<BR># CLASSITEM "TIPO"<BR>TRANSPARENCY 100<BR>CLASS<BR># =
EXPRESSION=20
"0"<BR>COLOR 255 255 255<BR>OUTLINECOLOR 0 0 =
0<BR>END<BR>END<BR><BR><BR># Fotos=20
A=E9reas=20
-----------<BR>LAYER<BR>NAME=20
"hpool"<BR>STATUS ON<BR>TILEINDEX "grade5m.shp"<BR>TILEITEM =
"LOCATION"<BR>TYPE=20
RASTER<BR>END<BR><BR>END</P>
<P><SPAN=20
class=3D978184218-17092003>.............................................=
........</SPAN></P>
<P><FONT face=3D'"Arial"' size=3D5><SPAN =
class=3D978184218-17092003>when I execute I=20
receive this message:</SPAN></FONT></P>
<P><FONT face=3D'"Arial"'><SPAN =
class=3D978184218-17092003></SPAN></FONT> </P>
class=3D978184218-17092003>loadForm(): Web=20
application error. Not enough arguments for imgxy. </SPAN></FONT></P>
<P><FONT face=3D'"Arial"' size=3D5><SPAN=20
class=3D978184218-17092003>thanks</SPAN></FONT></P>
<P><SPAN=20
class=3D978184218-17092003></SPAN> </P></FONT></SPAN></DIV></BODY><=
/HTML>
------_=_NextPart_001_01C37D4C.052B34D0--
Content-Type: image/gif;
name="=?iso-8859-1?Q?t=E9cn=2Egif?="
Content-Transfer-Encoding: base64
Content-Disposition: attachment;
filename="=?iso-8859-1?Q?t=E9cn=2Egif?="
Content-ID: <978184218 at 17092003-35da>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------_=_NextPart_000_01C37D4C.052B34D0--
