[Mapserver-users] help help help!
Don
mamwake at yahoo.com
Sat Sep 20 03:08:54 EDT 2003
hello all,am very new to mapserver and i want to have
web mapserver running, but i don't know howto.
below is my detailed configurations
Systems Info:
hp Proliant ML310 P IV(2Ghz)
18Gb SCSCI
128 Ram(2160)
OS=Redhat Linux 8.0
Webserver=Apache(httpd)2.0.40-8 rpm version
Applications:
# removed these and dependent rpms
rpm -e gd
rpm -e curl-7.9.8-1
rpm -e curl-devel-7.9.8-1
rpm -e php
# already have rpm installed
rpm -q libpng-1.2.2-8
rpm -q libpng-devel-1.2.2-8
rpm -q libjpeg-6b-21
rpm -q libjpeg-devel-6b-21
# installed
rpm -i pdflib-4.0.1-1.i386.rpm
# downloaded and built ming
tar xzf ming-0.2a.tgz
cd ming-0.2a
make
make static
make install
# downloaded and built curl
tar xzf curl-7.10.3.tar.gz
cd curl-7.10.3
./configure
make
make install
# added /usr/local/lib to /etc/ld.so.conf
/sbin/ldconfig
# downloaded and installed gd-2 into /usr/local
rm -f /usr/lib/libgd.*
tar xzf gd-2.0.11.tar.gz
cd gd-2.0.11
./configure
make
make install
# downloaded and installed gdal-1.1.8
tar xzf gdal-1.1.8.tar.gz
cd gdal-1.1.8
./configure \
--with-libz \
--with-png \
--with-libtiff=internal \
--with-geotiff=internal \
--with-jpeg \
--without-jasper \
--without-python
make
make ogr-all
make install
/sbin/ldconfig
# downloaded and built php-4.3.0
tar xzf php-4.3.0.tar.gz
cd php-4.3.0
rm -f config.cache
./configure \
--enable-force-cgi-redirect \
--enable-discard-path \
--with-config-file-path=/etc/httpd/ \
--with-gd=/usr/local \
--with-jpeg-dir \
--with-png-dir \
--with-zlib-dir \
--with-freetype-dir \
--without-ttf \
--with-pdflib \
--with-mysql \
--with-regex=system \
--with-ming \
--enable-dbase \
--enable-dbx \
--enable-versioning
make
cp sapi/cgi/php /var/www/cgi-bin
make install
cp php.ini-dist /etc/httpd/php.ini
diff /etc/httpd/php.ini php.ini-dist
extension_dir = /etc/httpd/php_mods
# downloaded and built proj libraries
tar xzf proj-4.4.5.tar.gz
cd proj-4.4.5/nad
tar xzf ../../proj-nad27-1.1.tar.gz
cd ..
./configure
make
make install
/sbin/ldconfig
# downloaded and built mapserver-3.6.6
tar xzf mapserver-3.6.6.tgz
cd mapServer-3.6.6
rm -f config.cache
./configure \
--without-tiff \
--without-eppl \
--without-jpeg \
--with-threads \
--with-proj \
--with-gdal=/usr/local/bin \
--with-php=../php-4.3.0 \
--with-freetype=/usr/bin \
--with-pdf \
--with-ogr \
--with-gdal \
--with-ming \
--with-wmsclient \
--with-wfs \
--with-wfs-client
make
cp legend mapserv scalebar /var/www/cgi-bin
cp mapscript/php3/php_mapscript.so
/etc/httpd/php_mods/
# added to /etc/httpd/conf/httpd.conf:
AddType application/x-httpd-php-cgi .php .php4 .phtml
Action application/x-httpd-php-cgi /cgi-bin/php
service httpd restart
# created /var/www/html/info.php
<?php
dl("php_mapscript.so");
phpinfo();
NB:// my major question is; how do i make maps or
else
what other configuration is needed?..this where i
have reached so far and am unable to get info on how
to create maps and make them work!!wht else is
needed?
pls help am very desparate!!
thanks in advance!
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
