[Mapserver-users] help help help!
    mapserver-users at lists.gis.umn.edu
    Sat Sep 20 07:16:36 PDT 2003
Hi Don,
OK, looks good so far. Is mapserver listed in the output if you go
to:
http://yourserver/info.php
If it does not show then you have an install problem for
php_mapscript. You can debug it now or try the demo application which
does not use php_mapscript.
The next step would be to get the demo application for ms-3.6.6. BTW
is there some reason you are not using ms-4.0 which is the current
release.
Then the next step is to get some data of whatever you would like to
draw maps of and create a mapfile to render it. This is often easiest
if you take the demo application and modify it to work with your
data. If you get stuck, the list has lots of people that are willing
to help. So just post a message with some details.
-Steve W.
On 20 Sep 2003 at 0:08, Don wrote:
> hello all,am  very new to mapserver and i want to have
> web mapserver running, but i don't know howto.
> below is my detailed configurations
> Systems Info:
> hp Proliant ML310 P IV(2Ghz)
>  18Gb SCSCI
>  128 Ram(2160)
>  OS=Redhat Linux 8.0
>  Webserver=Apache(httpd)2.0.40-8 rpm version
>  Applications:
>  # removed these and dependent rpms
>    rpm -e gd
>    rpm -e curl-7.9.8-1
>    rpm -e curl-devel-7.9.8-1
>    rpm -e php
>  # already have rpm installed
>    rpm -q libpng-1.2.2-8
>    rpm -q libpng-devel-1.2.2-8
>    rpm -q libjpeg-6b-21
>    rpm -q libjpeg-devel-6b-21
>  # installed
>    rpm -i pdflib-4.0.1-1.i386.rpm
>  # downloaded and built ming
>  tar xzf ming-0.2a.tgz
>  cd ming-0.2a
>  make
>  make static
>  make install
>  # downloaded and built curl
>  tar xzf curl-7.10.3.tar.gz
>  cd curl-7.10.3
>  ./configure
>  make
>  make install
>  # added /usr/local/lib to /etc/ld.so.conf
>  /sbin/ldconfig
>  # downloaded and installed gd-2 into /usr/local
>  rm -f /usr/lib/libgd.*
>  tar xzf gd-2.0.11.tar.gz
>  cd gd-2.0.11
>  ./configure
>  make
>  make install
>  # downloaded and installed gdal-1.1.8
>  tar xzf gdal-1.1.8.tar.gz
>  cd gdal-1.1.8
>  ./configure \
>    --with-libz \
>    --with-png \
>    --with-libtiff=internal \
>    --with-geotiff=internal \
>    --with-jpeg \
>    --without-jasper \
>    --without-python
>  make
>  make ogr-all
>  make install
>  /sbin/ldconfig
>  # downloaded and built php-4.3.0
>  tar xzf php-4.3.0.tar.gz
>  cd php-4.3.0
>  rm -f config.cache
>  ./configure \
>    --enable-force-cgi-redirect \
>    --enable-discard-path \
>    --with-config-file-path=/etc/httpd/ \
>    --with-gd=/usr/local \
>    --with-jpeg-dir \
>    --with-png-dir \
>    --with-zlib-dir \
>    --with-freetype-dir \
>    --without-ttf \
>    --with-pdflib \
>    --with-mysql \
>    --with-regex=system \
>    --with-ming \
>    --enable-dbase \
>    --enable-dbx \
>    --enable-versioning
>  make
>  cp sapi/cgi/php /var/www/cgi-bin
>  make install
>  cp php.ini-dist /etc/httpd/php.ini
>  diff /etc/httpd/php.ini php.ini-dist
>   extension_dir = /etc/httpd/php_mods
>  # downloaded and built proj libraries
>  tar xzf proj-4.4.5.tar.gz
>  cd proj-4.4.5/nad
>  tar xzf ../../proj-nad27-1.1.tar.gz
>  cd ..
>  ./configure
>  make
>  make install
>  /sbin/ldconfig
>  # downloaded and built mapserver-3.6.6
>  tar xzf mapserver-3.6.6.tgz
>  cd mapServer-3.6.6
>  rm -f config.cache
>  ./configure \
>    --without-tiff \
>    --without-eppl \
>    --without-jpeg \
>    --with-threads \
>    --with-proj \
>    --with-gdal=/usr/local/bin \
>    --with-php=../php-4.3.0 \
>    --with-freetype=/usr/bin \
>    --with-pdf \
>    --with-ogr \
>    --with-gdal \
>    --with-ming \
>    --with-wmsclient \
>    --with-wfs \
>    --with-wfs-client
>  make
>  cp legend mapserv scalebar /var/www/cgi-bin
>  cp mapscript/php3/php_mapscript.so
>  /etc/httpd/php_mods/
>  # added to /etc/httpd/conf/httpd.conf:
>  AddType application/x-httpd-php-cgi .php .php4 .phtml
>  Action  application/x-httpd-php-cgi /cgi-bin/php
>  service httpd restart
>  # created /var/www/html/info.php
>  <?php
>  dl("php_mapscript.so");
>  phpinfo();
>  NB:// my major question is; how do i make maps or
> else
>   what other configuration is needed?..this where i
>  have reached so far and am unable to get info on how
>  to create maps and make them work!!wht else is
> needed?
>  pls help am very desparate!!
>  thanks in advance!
> __________________________________
> Do you Yahoo!?
> Yahoo! SiteBuilder - Free, easy-to-use web site design software
> http://sitebuilder.yahoo.com
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users
