[Mapserver-users] help help help!
don
mamwake at yahoo.com
Sat Sep 20 11:21:35 EDT 2003
ye my php_mapscript is showing on info.php:
MapScript
MapServer Version MapServer version 3.6.6 OUTPUT=PNG
OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=TTF
SUPPORTS=WMS_SERVER INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
PHP MapScript Version ($Revision: 1.104.2.9 $ $Date:
2003/04/16 20:31:59 $)
what do u mean by getting data? i mean how do one get
that data?
i have downloaded a demo(gmap(3.6.6)) tarball and
untared it,,but when i try to load it, am getting
blank images,i can see the lenged bar/frame plus it's
contents, nothing on the image,says map loading then
says done but nothing loads!!when i view the /mstmp
extensions,though they never display!
examples:
what does this mean?
thanks very much for your reply!
--- woodbri at swoodbridge.com wrote:
> Hi Don,
> OK, looks good so far. Is mapserver listed in the
> output if you go
> to:
> http://yourserver/info.php
> If it does not show then you have an install problem
> for
> php_mapscript. You can debug it now or try the demo
> application which
> does not use php_mapscript.
> The next step would be to get the demo application
> for ms-3.6.6. BTW
> is there some reason you are not using ms-4.0 which
> is the current
> release.
> Then the next step is to get some data of whatever
> you would like to
> draw maps of and create a mapfile to render it. This
> is often easiest
> if you take the demo application and modify it to
> work with your
> data. If you get stuck, the list has lots of people
> that are willing
> to help. So just post a message with some details.
> -Steve W.
ronny
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
