[Mapserver-users] WMS layer alignment
Lowther, David W
dlowther at ou.edu
Mon Sep 22 08:55:50 EDT 2003
Brian,
I am having a similar issue with the new USGS photos, but not exactly the
same. My map is in an Albers variant and the USGS photo layer looks good at
larger scales, but at smaller scales - like when I am zoomed in to a house
or block level, I get white space to the right or bottom of the image -
making it appear squashed to the left or top. Did the REASPECT=false
parameter fix your issue? I have tried this and while I do see a difference,
it does not completely correct the behaviour I describe below.
Anyone else seen this behaviour?
It is viewable at 129.15.172.20/okstatedemo40.htm. Note that this USGS photo
layer is only available for Oklahoma City - in the very center of the map...
Thanks in advance,
David Lowther
Software Engineer
GEO Information Systems
University of Oklahoma
dlowther at ou.edu
(405) 325-3131
http://www.geo.ou.edu
PROJECTION # ALBERS OK
proj=aea
lat_1=29.500000000 #SP1
lat_2=45.500000000 #SP2
lat_0=23.000000000 #REF LAT
lon_0=-96.000000000 #CENTRAL MERIDIAN
x_0=0.000 #FALSE EAST
y_0=0.000 # FALSE NORTH
datum=NAD83
ellps=GRS80
no_defs
END
### OKC 2002 Ortho USGS-WMS ###
LAYER
NAME Urban133
GROUP Imagery
TYPE RASTER
STATUS ON
MAXSCALE 500000
#OFFSITE 255 255 255
CONNECTIONTYPE WMS
CONNECTION
"http://gisdata.usgs.net:80/servlet/com.esri.wms.Esrimap?SERVICENAME=133urba
n&REASPECT=FALSE&REQUEST=map"
PROJECTION
"init=epsg:4326" #WGS 84
END
METADATA
"NoID" "T"
"wms_name" "UA_ORTHO_302_01"
"wms_server_version" "1.0.0"
"wms_format" "image/jpeg"
"wms_title" "USGS Urban Color Ortho 2002"
"wms_style" ""
#"wms_extent" "-123.12987 45.241726 -122.3584 45.75648"
END
END
> -----Original Message-----
> From: Brian Johnson [mailto:spiff88gis at hotmail.com]
> Sent: Wednesday, September 17, 2003 9:37 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] WMS layer alignment
> I have a map file that uses a couple of WMS servers to add
> some nice images
> to my map. Specifically, I added the Terraserver orthos -
> and a relatively
> new server from the USGS - color orthos for many urban areas.
> My map file, the Terraserver WMS layer, and the shapefiles I
> am using are in
> NAD83 UTM zone 10N coordinate system. The USGS WMS layer is
> in WGS 84. All
> projections are set in the map file, and for each layer.
> When I turn on the
> Terraserver layer, the image is nicely displayed behind the
> shapefiles
> perfectly. When I turn on the USGS layer, the center of the image is
> perfectly aligned - and the rest of the image appears to be
> squashed - with
> apparently a larger Y-axis extent that the image should be.
> If I change the
> map projection to WGS 84, the the USGS layer now nicely
> aligns with the
> shapefiles, and so does the Terraserver image - with no reprojection
> problem.
> Any suggestions as to where my problem might be? I'd like to
> have the map
> in UTM project for how it looks compared to WGS - but I can't
> figure out why
> the WGS 84 layer is not reprojecting correctly.
> Below are the sections from my .map file...
> Thanks for any ideas!
> Brian
> #---Map file projection info---
> PROJECTION
> "init=epsg:26910"
> END
> #---Terraserver Layer---
> LAYER
> NAME ortho
> METADATA
> "wms_title" "USGS Digital Ortho-Quadrangles"
> "wms_srs" "EPSG:26910" #NAD83 UTM zone 10N
> LYRNAME "DOQs (orthophotos)"
> LINK
> "http://terraserver.microsoft.com/about.aspx?n=AboutTerraServi
ceOverview"
END
GROUP "BASE DATA"
STATUS OFF
TYPE RASTER
MINSCALE 10
MAXSCALE 240000
CONNECTIONTYPE WMS
CONNECTION
"http://terraservice.net/ogcmap.ashx?VERSION=1.1.1&SERVICE=wms&LAYERS=DOQ&FO
RMAT=png&styles="
PROJECTION
"init=epsg:26910" #NAD83 UTM zone 10N
END
END
#---USGS Portland, OR area layer---
LAYER
NAME Urban133
METADATA
"wms_title" "Portland Ortho 2002"
LYRNAME "Urban133"
LINK "N/A"
END
OFFSITE 255 255 255
GROUP "Urban133"
STATUS ON
TYPE RASTER
CONNECTIONTYPE WMS
CONNECTION
n&VERSION=1.0.0&REQUEST=map&LAYERS=UA_ORTHO_313_01&STYLES=&FORMAT=JPEG&"
PROJECTION
END
END
_________________________________________________________________
Need more e-mail storage? Get 10MB with Hotmail Extra Storage.
http://join.msn.com/?PAGE=features/es
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
