[Mapserver-users] question re Perl queryByShape
Puneet Kishor
pkishor at geoanalytics.com
Mon Sep 22 09:59:52 EDT 2003
as I understand, here's the logic for querying by shape --
1. create a shape to query with (queryShpObj)
my $queryShpObj = new blah blah;
2. call queryByShape on the map object (mapObj) using the above shape
$mapObj->queryByShape($queryShpObj);
Now, herein lies my question -- how does mapobject know which layer to
query against? The intuitive model that I have learned (the Pavlovian
Arcview way) is that you have first choose a layer before you can query
against it. Even if we extend that model, we can make it plural...
choose the layer or layers against which to query. So the syntax should
be somewhat like
my $queryLayerObj = new blah blah (proabably with a getLayerByName);
$mapObj->queryByShape($queryShpObj, $queryLayerObj);
Once that is done then one could(should) work with the $resultCacheObj
my $resultCacheObj = $queryLayerObj->{resultcache};
Not specifying the queryLayer(s) in step 2 above -- doesn't that make
things slower?
