[Mapserver-users] question re Perl queryByShape
Eric Bridger
eric at gomoos.org
Mon Sep 22 07:03:30 EDT 2003
The functionality you want already exists.
Both the map and layer objects have queryByShape() methods. So
$mapObj->queryByShape() will query all layers which are ON.
$layerObj->queryByShape() queries only that layer.
On Mon, 2003-09-22 at 13:59, Puneet Kishor wrote:
> as I understand, here's the logic for querying by shape --
> 1. create a shape to query with (queryShpObj)
> my $queryShpObj = new blah blah;
> 2. call queryByShape on the map object (mapObj) using the above shape
> $mapObj->queryByShape($queryShpObj);
> Now, herein lies my question -- how does mapobject know which layer to
> query against? The intuitive model that I have learned (the Pavlovian
> Arcview way) is that you have first choose a layer before you can query
> against it. Even if we extend that model, we can make it plural...
> choose the layer or layers against which to query. So the syntax should
> be somewhat like
> my $queryLayerObj = new blah blah (proabably with a getLayerByName);
> $mapObj->queryByShape($queryShpObj, $queryLayerObj);
> Once that is done then one could(should) work with the $resultCacheObj
> my $resultCacheObj = $queryLayerObj->{resultcache};
> Not specifying the queryLayer(s) in step 2 above -- doesn't that make
> things slower?
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
