[Mapserver-users] help with annotations
Dylan Keon
keon at nacse.org
Mon Sep 22 20:16:40 EDT 2003
That's pretty much how I think of it, although that doesn't necessarily
mean it's correct :-) From the mapfile reference:
"Annotation means that a label point will be calculated for the
features, but the feature itself will not be drawn although a marker
symbol can be optionally drawn."
--Dylan
Matt Doggett wrote:
> This is exactly what I'm doing except I'm using TYPE POINT, rather than
> TYPE ANNOTATION. So what's the difference between POINT and ANNOTATION?
> Let me guess, A POINT layer has both a point SYMBOL and a LABEL at each
> x,y coordinate of the points in the layer. But the ANNOTATION layer has
> only a LABEL at each of the points. Is this correct? Perhaps I've come
> full circle now back to my original question trying to understand
> annotation layers (of which I still have not found an adequate
> explanation).
> Matt
>>-----Original Message-----
>>From: Dylan Keon [mailto:keon at nacse.org]
>>Sent: Monday, September 22, 2003 4:27 PM
>>To: mdoggett at coas.oregonstate.edu
>>Cc: mapserver-users at lists.gis.umn.edu
>>Subject: Re: [Mapserver-users] help with annotations
>>Matt,
>>I'm not sure this is what you're after, but in one of my PHP apps I
>>label dynamically-created lines with text from user input. Assuming
> you
>>want to build your label text from database content, just run the
> query,
>>construct your several-item label ahead of time, and assign it to a
>>variable (or push the labels into an array). That variable would
>>replace "$label[$i]" in the code example below (which is part of a for
>>loop that adds the labels after I've rendered the lines):
>> $pt = ms_newLineObj();
>> $pt->addXY($x, $y);
>> $shape = ms_newShapeObj(MS_SHAPE_POINT);
>> $shape->set('classindex', 0);
>> $shape->set('text', $label[$i]); // assign the label
>> $shape->add($pt);
>> $layer = $map->getLayerByName('line_annotation');
>> $shape->draw($map, $layer, $image);
>> $pt->free();
>> $shape->free();
>>Here's the corresponding entry in my mapfile:
>>LAYER
>> NAME line_annotation
>> STATUS ON
>> TYPE ANNOTATION
>> FEATURE
>> END
>> CLASS
>> LABEL
>> TYPE TRUETYPE
>> FONT arial
>> SIZE 10
>> COLOR 0 0 0
>> POSITION UC
>> FORCE TRUE
>> END
>> END
>>END
>>--Dylan
>> Dylan Keon - GIS/Database Specialist
>> Northwest Alliance for Computational Science and Engineering
>> Oregon State University
>> Corvallis, OR 97331
>> keon at nacse.org voice: 541-737-6608 fax: 541-737-6609
>>Matt Doggett wrote:
>>>Someone else had suggested this same technique, and I've seen it in
> the
>>>documentation. But where do the values [FIRSTNAME] [LASTNAME] come
> from?
>>>My guess is that they are attribute 'columns' in the shape file. But
>>>here's the problem. My shape object is created dynamically with
>>>Php/Mapscript (from a query to a postgres database). I see that the
>>>ShapeObj class has the values array but apparently it is read-only so
>>>that I cannot dynamically create the data columns
>>>([TEMP],[DEWPT],[WIND], etc) that this method would require. This
>>>problem is off topic but are there any suggestions?
>>>md
>>>>From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-
>>>>admin at lists.gis.umn.edu] On Behalf Of Lowell Filak
>>>>Sent: Monday, September 22, 2003 1:04 PM
>>>>To: Matt Doggett; 'Tyler Mitchell'; mapserver-users at lists.gis.umn.edu
>>>>Subject: RE: [Mapserver-users] help with annotations
>>>>You can specify multiple 'text' attributes for the class, ie.
>>>>([FIRSTNAME],[LASTNAME]) .
>>>>Lowell
>>>>The following message was sent by "Matt Doggett"
>>>><mdoggett at coas.oregonstate.edu> on Mon, 22 Sep 2003 12:36:53 -0700.
>>>>>Well, I have a single point layer that contains weather station
> data.
>>>I
>>>>>currently have it so that the label (actually the 'text' attribute
> of
>>>>>the shape object) contains the station identifier. In addition to
>>>this,
>>>>>I also would like to be able to display one, some, all of additional
>>>>>data like temp, dewpt, winds, etc.
>>>>>None of the responses so far has suggested annotations so maybe
>>>that's
>>>>>not the direction I need to be going.
>>>>>matt
>>>>>>admin at lists.gis.umn.edu] On Behalf Of Tyler Mitchell
>>>>>>Sent: Monday, September 22, 2003 11:18 AM
>>>>>>To: mapserver-users at lists.gis.umn.edu
>>>>>>Do you just want to create labels that use more than one line (i.e.
>>>>>>multi-line labels) and use more than one attribute? Are you
> already
>>>>>>displaying labels okay? You can do all this using similar
>>>methodology
>>>>>as
>>>>>>far as I know. Maybe give us a short example of what you are
>>>already
>>>>>>doing and how you'd like that to change.
>>>>>>Tyler
>>>>>>mapserver-users-admin at lists.gis.umn.edu wrote on 09/22/2003
> 10:45:36
>>>>>AM:
>>>>>>>I have some point data where I want to display more than one data
>>>>>value
>>>>>>in
>>>>>>>the labels at each data point (eg. Temperature, windspeed, dewpt,
>>>>>etc).
>>>>>>How
>>>>>>>would I do this? I'm thinking that this would involve annotation
>>>>>layers
>>>>>>but
>>>>>>>I can't find any documentation that says exactly what they are or
>>>how
>>>>>to
>>>>>>use
>>>>>>>them. Can anyone shed some light on how to use annotation layers?
>>>>>I'm
>>>>>>>using PHP/Mapscript if that helps.
>>>>>>>TIA,
>>>>>>>Matt
>>>>>>>Matt Doggett
>>>>>>>Spatial Climate Analysis Service
>>>>>>>316 Strand Ag Hall
>>>>>>>Corvallis, OR 97331
>>>>>>>(541)737-9153
