[Mapserver-users] can I use different symbols in the same
dynamic layer?
Eric Bridger
eric at gomoos.org
Tue Sep 23 07:09:41 EDT 2003
I do this all the time. You probably could acheive this using CLASSITEM
and EXPRESSION, but typically I'll use a layer with a single class for
such a layer. Then based on my data: (Perl mapscript, sorry not PHP)
my $sym_idx_1 = $map->getSymbolByName("symbol_1");
my $sym_idx_2 = $map->getSymbolByName("symbol_2");
my $class = $layer->getClass(0);
if(we want symbol 1){
$class->{symbol} = $sym_idx_1;
if(we want symbol 2){
$class->{symbol} = $sym_idx_2;
$point->draw($map, $layer, $img, 0, 'label');
HTH
Eric
On Tue, 2003-09-23 at 07:45, Frieso ter Haseborg wrote:
> Hi,
> I'm using PHP/MapScript to draw dynamic point-layers in a map. What I
> would like to do is using different symbols for different points in the
> same layer. Is there any way to achieve this using the mapfile
> (expressions or something) or can this be done using PHP/MapScript?
> Here are parts of my setup:
> //points are created with mapscript
> $pt = ms_newPointObj();
> $pt->setXY( -700000, 5950000 );
> $pt->draw($map, $layer, $image, 0, "Pt1");
> //Symbol- and label-attributes are specified in the mapfile.
> LAYER
> NAME p
> TYPE POINT
> STATUS ON
> #CLASSITEM "" //is there a classItem when creating a layer dynamic?
> CLASS
> SYMBOL 17
> COLOR 128 128 255
> SIZE 35
> #EXPRESSION "" //would this work, when having a
> classitem on a dynamic layer?
> LABEL
> POSITION AUTO
> END
> END
> END
> I had some attempts using a class/expression, but since I don't know the
> correct classItem I think this can't work. Well, is there a possible
> "classitem" at all, when the layer isn't retrieved from a shapefile?
> Is there a way to do this, or must there be different layers for each
> symbol-type?
> Any hints would be appreciated.
> TIA,
> Frieso ter Haseborg
> - Software Development -
> S&F Datentechnik GmbH&Co.KG
> Reimersstr. 41b
> 26789 Leer, Germany
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
