[Mapserver-users] Upward compatibility problem pixmap symbol
Claude Philipona
claude-mapserver at skirando.ch
Wed Sep 24 09:12:11 EDT 2003
Hello,
I think there an upward compatibility problem concerning SYMBOL use in
Mapserver 4.0. Mapserver 4.0 introduces STYLE object which extends the way
to use symbol. Old mapfile (Mapserver 3.6), still work with Mapserver 4.0,
even if STYLE is not used. I think there is one exception, when the symbol
is of PIXMAP type, the symbol is never represented on the the map, except
if SYMBOL and SIZE are declared inside a STYLE object. Labels are present in
any case.
This will never represent any symbol on the map in mapserver 4.0:
CLASS
EXPRESSION /bus/
NAME "bus"
SYMBOL "bus"
SIZE 18
END
This will represent symbols on the map in mapserver 4.0:
CLASS
EXPRESSION /bus/
NAME "bus"
STYLE
SYMBOL "bus"
SIZE 18
END
END
I don't now if this behaviour is normal, but telling the list about it...
it can take some time to figure out why the labels are not showing up.
... portion of mapfile:
LAYER
NAME "transport"
TYPE POINT
STATUS ON
DATA "general/transport"
CLASSITEM "TYPE"
CLASS
EXPRESSION /bus/
NAME "bus"
STYLE
SYMBOL "bus"
SIZE 18
END
END
END
... portion of symbolfile:
Symbol
Name 'bus'
Type PIXMAP
END
Claude Philipona
