[Mapserver-users] No layer colors
    William Hudspeth
    bhudspeth at edac.unm.edu
    Wed Sep 24 14:46:00 PDT 2003
Hello all,
I have recently set up Mapscript 4.0 (which otherwise is working great)
on a new server , and I am trying to run a script and associated mapfile
that I know works on an older installation. My problem is, when I try to
display data layers, whether point, line, or polygon, their defined
colors (as specified in the mapfile) do not appear. They are all
displayed as shades of gray.
I suspect that it may have something to do with my system and Mapserver
configuration parameters. They are as follows:
./configure --with-postgis --with-proj --with-gdal --with-wmsclient
--with-pdf --with-pgsql --with-gd=/usr/local/src/gd-2.0.15
--with-php=/usr/local/src/php-4.3.3 --with-wms --without-tiff
Newly installed packages include:
gd-2.0.15
gdal-1.1.9
curl-7.10.7
libgeotiff-1.2.1
PDFlib-5.0.1
php-4.3.3
proj 4.4.7
postgis-0.7.5
postgresql-7.3.4
Thanks in advance for the help,
Bill
More information about the MapServer-users
