[Mapserver-users] WMS using libCurl fails because of a wrong HTTP User Agent
Norbert Schauerte-Lueke
nsl at regio-gis-planung.de
Thu Sep 25 04:46:26 EDT 2003
HI Tom,
This is the URL of the server. If I use the patch given from Daniel it
works.
http://www.geoserver.nrw.de/GeoOgcWms1.3/servlet/GEPNRW
?VERSION=1.1.0&SERVICE=wms&REQUEST=GetMap&LA
YERS=GEPNRW:Gewerbe&STYLES=,,&SRS=EPSG:31466&
BBOX=2531220,5704038,2541515,5715184&WIDTH=700&H
EIGHT=500&FORMAT=image/png&TRANSPARENT=true&
EXCEPTIONS=application/vnd.ogc.se_inimage
The MapServer Software that is used comes form AED-Sicad. But I
think they try to fix that problem.
Greetings Norbert.
On 24 Sep 2003 at 15:53, Tom.Kralidis at CCRS.NRCan.gc.ca wrote:
> Hi,
> It should not make a difference what the user agent is. OGC WMS is
> independent of what client one uses.
> If the particular WMS you are dealing with is disallowing requests from
> certain user agents, that is specific to the way it may have been
> configured. It is outside the scope of the specification.
> Do you have the server URL of the WMS you're trying to access?
> Thanks
> ..Tom
> > -----Original Message-----
> > From: Daniel Morissette [mailto:morissette at dmsolutions.ca]
> > Sent: Wednesday, September 24, 2003 3:08 PM
> > To: Norbert Schauerte-Lueke
> > Cc: mapserver-users at lists.gis.umn.edu
> > Subject: Re: [Mapserver-users] WMS using libCurl fails because of a
> > Norbert Schauerte-Lueke wrote:
> > > still there is a problem with the UMN wms-client and a
> > propritary WMS
> > > Server. The diagnostic of the problem show that the WMS Client will
> > > only send an image when the HTTP User Agent will be MSIE or
> > > Mozilla. libCurl sets an other HTTP User Agent (somethink like CURL
> > > Version ...). Is there a possibility to change this HTTP
> > User Agent e.g.
> > > via an environment variable.
> > > If anybody can give a hint, I will be very thankfull
> > I find it really odd that a WMS server would cehck the user agents
> > before responding to client requests, but anyway, there is
> > apparently a
> > way to control the user agent value with Libcurl. If you can
> > build from
> > source, then you could add the following line to maphttp.c
> > around line
> > 339, just after the line that sets CURLOPT_URL:
> > curl_easy_setopt(http_handle, CURLOPT_USERAGENT, "whatever
> > you want");
> > Daniel
> > Daniel Morissette morissette at dmsolutions.ca
> > DM Solutions Group http://www.dmsolutions.ca/
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
R E G I O G I S + P L A N U N G G m b H
www.regio-gis-planung.de
Falkstraße 73-77, 47058 Duisburg
Tel. 0203 / 30511-360
Fax: 0203 / 30511-364
Hainhölzer Strasse 5, 30159 Hannover
Tel. 0511 / 123577-0
Fax: 0511 / 123577-11
