[Mapserver-users] terrible fix
Swaminathan, Gayathri
gayathri at ou.edu
Thu Sep 25 12:49:19 EDT 2003
Hi:
Your web template is a path listed in your map file "demo.map"
If you open your demo.map and find lines....
"WEB
EMPTY "PATH TO HTML PAGE TO SHOW WHEN NO RECORDS WERE FOUND"
TEMPLATE "PATH TO YOUR WEB TEMPLATE.HTM"
IMAGEPATH "e:\inetpub\wwwroot\tmp\"
IMAGEURL "/tmp/""
And verify/change the ones in caps, that should help. Yes, you should also
take Ed's help on the
Units/meters..and mapext....
Extensive resources regarding these can be found in the
http://mapserver.gis.umn.edu documentation and the wiki.
Thanks
-----Original Message-----
Sent: Thursday, September 25, 2003 11:08 AM
To: Swaminathan, Gayathri
Cc: mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] terrible fix
what do u mean by web template? is it imagepath or
imageurl? to be sincere am very very new to
mapservers.
--- "Swaminathan, Gayathri" <gayathri at ou.edu> wrote:
> Ronny,
> How is the web template mentioned in your mapfile?
> Check on that path.
> Gayathri
ronny
__________________________________
Do you Yahoo!?
The New Yahoo! Shopping - with improved product search
http://shopping.yahoo.com
