[Mapserver-users] terrible fix
ronny
mamwake at yahoo.com
Fri Sep 26 04:24:21 EDT 2003
i have checked but i cann't see those lines! FYI am on
linux system not windows.
thanks.
--- "Swaminathan, Gayathri" <gayathri at ou.edu> wrote:
> Hi:
> Your web template is a path listed in your map file
> "demo.map"
> If you open your demo.map and find lines....
> "WEB
> EMPTY "PATH TO HTML PAGE TO SHOW WHEN NO RECORDS
> WERE FOUND"
> TEMPLATE "PATH TO YOUR WEB TEMPLATE.HTM"
> IMAGEPATH "e:\inetpub\wwwroot\tmp\"
> IMAGEURL "/tmp/""
> And verify/change the ones in caps, that should
> help. Yes, you should also
> take Ed's help on the
> Units/meters..and mapext....
> Extensive resources regarding these can be found in
> the
> http://mapserver.gis.umn.edu documentation and the
> wiki.
> Thanks
ronny
__________________________________
Do you Yahoo!?
The New Yahoo! Shopping - with improved product search
http://shopping.yahoo.com
