[Mapserver-users] terrible fix
Eduardo Spremolla
edspremolla at Antel.com.uy
Fri Sep 26 05:10:58 PDT 2003
So in linux here you got my web definition:
WEB
TEMPLATE uru.html
IMAGEPATH "/var/www/html/tmp/"
IMAGEURL "/tmp/"
END
IMGEPATH must be absolute and IMGEURL relative to HTTPROOT of your
apache.
LALO
El vie, 26 de 09 de 2003 a las 05:24, ronny escribió:
> i have checked but i cann't see those lines! FYI am on
> linux system not windows.
> thanks.
> --- "Swaminathan, Gayathri" <gayathri at ou.edu> wrote:
> > Hi:
> > Your web template is a path listed in your map file
> > "demo.map"
> > If you open your demo.map and find lines....
> > "WEB
> > EMPTY "PATH TO HTML PAGE TO SHOW WHEN NO RECORDS
> > WERE FOUND"
> > TEMPLATE "PATH TO YOUR WEB TEMPLATE.HTM"
> > IMAGEPATH "e:\inetpub\wwwroot\tmp\"
> > IMAGEURL "/tmp/""
> > And verify/change the ones in caps, that should
> > help. Yes, you should also
> > take Ed's help on the
> > Units/meters..and mapext....
> > Extensive resources regarding these can be found in
> > the
> > http://mapserver.gis.umn.edu documentation and the
> > wiki.
> > Thanks
> ronny
> __________________________________
> Do you Yahoo!?
> The New Yahoo! Shopping - with improved product search
> http://shopping.yahoo.com
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users
