[Mapserver-users] can I use different symbols inthesamedynamiclayer?
Frieso ter Haseborg
ter-haseborg at sf-datentechnik.de
Fri Sep 26 06:10:21 EDT 2003
yes my symbol changes, due to your help! ;-)
But the color doesn't.
Here's the layer part of my mapfile:
LAYER
NAME p
TYPE POINT
STATUS ON
CLASS
SYMBOL 1
COLOR 255 0 0 //initialize symbols in red - will be changed by php
later
SIZE 40
LABEL
COLOR 0 0 0
SIZE medium
POSITION AUTO
END
END
END
I extended my mapscript with a "$map->save"-Command as mentioned by
Vinko in the next post:
$class = $layer->getClass(0);
$style = $class->getStyle(0);
$style->color->setRGB(0, 0, 255); //draw a blue point
$style->set ( 'symbol', $sym1 );
$pt->setXY( 2100000, 10100000 );
$pt->draw($map, $layer, $image, 0, "Pt1");
$map->save('test.map');
$class = $layer->getClass (0); //new class instance
$style = $class->getStyle(0); //new style instance
$style->color->setRGB(0, 255, 0); //draw a green one -
//!this failes, second symbol
becomes blue also!
$style->set ( 'symbol', $sym2 );
$pt->setXY( 4400000, 10000000 );
$pt->draw($map, $layer, $image, 0, "Pt2");
$map->save('test2.map');
This gives the following outputs in the layer-section:
//test.map
LAYER
NAME "p"
SIZEUNITS PIXELS
STATUS ON
TOLERANCE 0
TOLERANCEUNITS PIXELS
TYPE POINT
UNITS METERS
CLASS
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 0 0 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
POSITION AUTO
END
STYLE
COLOR 0 0 255 // blue for the first point
MAXSIZE 100
MINSIZE 1
SIZE 40
SYMBOL 16 // that's sym1
END
END
END
//test2.map
LAYER
NAME "p"
SIZEUNITS PIXELS
STATUS ON
TOLERANCE 0
TYPE POINT
UNITS METERS
CLASS
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 0 0 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
POSITION AUTO
END
STYLE
COLOR 0 255 0 // green for the second point,
// so it's correct in the map,
// but not on the screen. I'm confused!
MAXSIZE 100
MINSIZE 1
SIZE 40
SYMBOL 17 // that's sym2
END
END
END
So obviously the changes are stored in the map, but they don't take any
effect.
TIA,
Frieso
>-----Original Message-----
>From: Eric Bridger [mailto:eric at gomoos.org]
>Sent: Thursday, September 25, 2003 1:46 PM
>To: Frieso ter Haseborg
>Subject: RE: [Mapserver-users] can I use different symbols
>This works for me using Mapserver 3.6. I sincerely hope it
>works in 4.0
>since I plan to upgrade soon. Perhaps you should show us the relevant
>section of you map file.
>Does your symbol change? Just not the color?
>On Thu, 2003-09-25 at 15:00, Frieso ter Haseborg wrote:
>> Hi Eric,
>> nope, no success so far. I tried this:
>> $pt = ms_newPointObj();
>> $style->color->setRGB(0, 255, 0); //draw a green one - !this failes,
>> second symbol becomes blue also!
>> What am I doing wrong? :-(
>> TIA,
>> Frieso
>> >Sent: Wednesday, September 24, 2003 1:15 PM
>> >Cc: Mapserver List
>> >Subject: RE: [Mapserver-users] can I use different symbols in
>> >I wasn't very clear. Not a new class, a new class instance. Or, for
>> >MS4.0, a new style instance. So your layer would have 1 class and 1
>> >sytle. For each point you want to draw, in psuedo code:
>> >$layer = getLayerByName()
>> >$point = new pointObj(); # the point can be re-used.
>> >foreach lat, lon {
>> > $style = $class->getSytle(0);
>> > # set your style attributes, symbol, color, etc.
>> > $point->draw();
>> >On Wed, 2003-09-24 at 15:02, Frieso ter Haseborg wrote:
>> >> Hi,
>> >> okay: new color, new class - sounds good, I think. But -
>here comes
>> >> another newbie-question - how do I tell the points to which
>> >class they
>> >> belong???
>> >> Doesn't this lead back to the
>CLASSITEM/EXPRESSION-question or am I
>> >> missing something?
>> >> TIA,
>> >> Frieso
>> >> >Sent: Wednesday, September 24, 2003 12:02 PM
>> >> >Cc: Mapserver List
>> >> >thesamedynamic layer?
>> >> >You're right Frieso,
>> >> >I am still using 3.6
>> >> >The issue you mention below exists in 3.6 as well. What
>> >you need to do
>> >> >is to get a new class for each point and set the color and
>> >symbol anew.
>> >> >On Wed, 2003-09-24 at 09:27, Frieso ter Haseborg wrote:
>> >> >> Hi,
>> >> >> one more question: Can't I change the color the same way? After
>> >> >> successfully using different symbols, I tried to change the
>> >> >color of the
>> >> >> symbols also. But a color-change only takes effect for the
>> >> >first change
>> >> >> resp. for the first symbol drawn. All subsequent symbols
>> >are drawn in
>> >> >> _this_ new color also, but not in the individual color
>> >specified for
>> >> >> each symbol.
>> >> >> My PHP/MapScript goes like this:
>> >> >> $sym1 = $map->getSymbolByName ( "excl" );
>> >> >> $sym2 = $map->getSymbolByName ( "tent" );
>> >> >> // first point
>> >> >> $style->color->setRGB(0, 0, 255); // now the next point will
>> >> >change to
>> >> >> blue
>> >> >> // (symbols
>in mapfile are
>> >> >> initialized in red)
>> >> >> // THIS
>CHANGE WORKS!
>> >> >> // second point
>> >> >> $style->color->setRGB(0, 255, 0); // now the next
>point IMO should
>> >> >> become green, but it doesn't, it stays blue
>> >> >> // THIS
>CHANGE FAILES!
>> >> >> Am I overlooking something or is there any restriction
>I ran into?
>> >> >> TIA,
>> >> >> Frieso ter Haseborg
>> >> >> - Software Development -
>> >> >> S&F Datentechnik GmbH&Co.KG
>> >> >> Reimersstr. 41b
>> >> >> 26789 Leer, Germany
>> >> >> >From: Frieso ter Haseborg
>> >> >> >Sent: Wednesday, September 24, 2003 9:52 AM
>> >> >> >To: Eric Bridger
>> >> >> >Cc: mapserver-users at lists.gis.umn.edu
>symbols in the
>> >> >> >samedynamic layer?
>> >> >> >Hi Eric,
>> >> >> >thanx, yes this helped a lot. It works - but so far
>only, when
>> >> >> >using the StyleObj-Class.
>> >> >> >I did the following in PHP:
>> >> >> >[...]//draw point1
>> >> >> >[...]//draw point2
>> >> >> >It looks like the symbol attribute is obsolete in MS and
>> >> >> >PHP/MapScript version 4.0, though no error is raised. It
>> >> >> >simply effects nothing in my configuration. Which version
>> >> >do you use?
>> >> >> >Anyway it works, thanx again!
>> >> >> >Best regards,
>> >> >> >Frieso ter Haseborg
>> >> >> >Reimersstr. 41b
>> >> >> >26789 Leer, Germany
>> >> >> _______________________________________________
>> >> >> Mapserver-users mailing list
>> >> >> Mapserver-users at lists.gis.umn.edu
>> >> >> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
