[Mapserver-users] can I use different symbols in thesamedynamiclayer?
Frieso ter Haseborg
ter-haseborg at sf-datentechnik.de
Fri Sep 26 06:40:25 EDT 2003
$map-output are the follows:
//test.map
LAYER
NAME "p"
SIZEUNITS PIXELS
STATUS ON
TOLERANCE 0
TOLERANCEUNITS PIXELS
TYPE POINT
UNITS METERS
CLASS
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 0 0 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
POSITION AUTO
END
STYLE
COLOR 0 0 255 // blue for the first point
MAXSIZE 100
MINSIZE 1
SIZE 40
SYMBOL 16 // that's sym1
END
END
END
//test2.map
LAYER
NAME "p"
SIZEUNITS PIXELS
STATUS ON
TOLERANCE 0
TYPE POINT
UNITS METERS
CLASS
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 0 0 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
POSITION AUTO
END
STYLE
COLOR 0 255 0 // green for the second point,
// so it's correct in the map,
// but not on the screen. I'm confused!
MAXSIZE 100
MINSIZE 1
SIZE 40
SYMBOL 17 // that's sym2
END
END
END
So obviously the changes are stored in the map, but they don't take any
effect.
>$class = $layer->getClass(0);
>$style = ms_newStyleObj($class);
>$style->color->setRGB(...
This takes no effect either.
>$class = ms_newClassObj($layer);
>//Here copy the properties of the original class to the new ones as in:
>$originalclass = $layer->getClass(0);
>$class->set('name',$originalclass->name); //and so on
This way I get a new class, but the also no effect on the symbol
//Here's the map-output:
LAYER
NAME "p"
SIZEUNITS PIXELS
STATUS ON
TOLERANCE 0
TYPE POINT
UNITS METERS
CLASS
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 0 0 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
POSITION AUTO
END
STYLE
COLOR 0 255 0
MAXSIZE 100
MINSIZE 1
SIZE 40
SYMBOL 17
END
END
CLASS
STYLE
COLOR 0 255 0
MAXSIZE 100
MINSIZE 1
SIZE 1
SYMBOL 1
END
END
END
IMHO this can't take any effect since I got a new class, but the next
point doesn't know it has to use this new class.
Do you've a working example for this operation?
TIA,
Frieso
>-----Original Message-----
>From: Vinko Vrsalovic [mailto:vinko at cprsig.cl]
>Sent: Friday, September 26, 2003 2:06 AM
>To: Frieso ter Haseborg
>Cc: Eric Bridger; mapserver-users at lists.gis.umn.edu
>Subject: Re: [Mapserver-users] can I use different symbols in
>On Thu, Sep 25, 2003 at 05:00:25PM +0200, Frieso ter Haseborg wrote:
>> Hi Eric,
>> nope, no success so far. I tried this:
>> $pt = ms_newPointObj();
>> $style = $class->getStyle(0);
>> $style->color->setRGB(0, 0, 255); //draw a blue point
>> $style->set ( 'symbol', $sym1 );
>> $pt->setXY( 2100000, 10100000 );
>> $pt->draw($map, $layer, $image, 0, "Pt1");
>> $class = $layer->getClass (0); //new class instance
>> $style = $class->getStyle(0); //new style instance
>> $style->color->setRGB(0, 255, 0); //draw a green one - !this failes,
>> second symbol becomes blue also!
>> $style->set ( 'symbol', $sym2 );
>> $pt->setXY( 4400000, 10000000 );
>> $pt->draw($map, $layer, $image, 0, "Pt2");
>Have you checked the output of $map->save()?
>I think your problem is here:
>These are not _new_ instances, just the same instances as in the first
>paragraph of your code, to draw different colors in the same class, you
>must add new styles, so try this (untested):
>If this doesn't work you could try creating different classes for
>each point:
>Vinko Vrsalovic <el[|- at -|]vinko.cl>
>http://www.cprsig.cl
