[Mapserver-users] open polygons makes mapserver crash
Daniel Morissette
morissette at dmsolutions.ca
Fri Sep 26 09:03:22 EDT 2003
Eduardo Patto Kanegae wrote:
> # some moments after I post this message, I ran the 'shptree' against my
> shapefile and the crashing stopped.
Well, this is just hiding the problem and it may come back. It would
probably still be a good idea to submit a bug if you have a data file
that can produce a crash (make sure you include sample mapfile and data
in the bug).
> # but one strange thing is that in my application(which is CGI mode) I have
> two maps: one is main Map[map]
> and the other is a reference map[ref], which is 1/3 of Main map dimensions.
> The reference was drawing OK, but
> the main map(the bigger) was crashing.
That's because the reference map is not drawn by reading the shapefiles:
it's just a precanned gif or png image on which MapServer draws a box.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
