[Mapserver-users] Can't get raster layer to work
Matthew Haines
mhaines94108 at hotmail.com
Sat Sep 27 13:43:01 EDT 2003
Once again I've hit a wall. I just want to display a map with a simple
bitmap image.
My map file is below. The map image that is generated is blank (all white).
Can
anyone see the problem?
Through experimentation I've discovered that it doesn't matter if the name
of the
bitmap image is correct or not -- mapserver doesn't give an error.
I'm using MapServer 4.0 with GDAL and OGR installed. I know the latter two
work
because I've used them to read .TAB files.
Some other questions about using raster data ...
How do I determine the EXTENT?
What effect does UNITS have?
How does the SCALE (or MINSCALE/MAXSCALE) relate to the size of the image
and the EXTENT?
Thanks in Advance,
Matthew
http://www.nycPropertyResearch.com
# Start of map file
MAP
IMAGETYPE PNG24
NAME zoning
STATUS ON
SIZE 600 600
EXTENT 0 0 4000 4000
UNITS FEET
SHAPEPATH "/var/www/html/maps/zoning"
FONTSET "/var/www/html/maps/fontset/fontset.txt"
WEB
HEADER demo_header.html
TEMPLATE demo.html
FOOTER demo_footer.html
MINSCALE 10
MAXSCALE 400
IMAGEPATH "set in demo_init.html"
IMAGEURL "set in demo_init.html"
END
# Start of layer definitions
LAYER
NAME zoningmap
DATA "map6a.bmp"
STATUS DEFAULT
TYPE RASTER
STATUS ON
END
END # Map File
_________________________________________________________________
Get MSN 8 Dial-up Internet Service FREE for one month. Limited time offer--
sign up now! http://join.msn.com/?page=dept/dialup
