MapScript Documentation (Re: [Mapserver-users] Re: problem getting bounds of poly shape)
Lowell Filak
lfilak at medinaco.org
Mon Sep 29 11:44:02 EDT 2003
Good question.
I'll have to try and reproduce it to know.
Lowell
The following message was sent by "pkishor_98"
<pkishor at geoanalytics.com> on Fri, 26 Sep 2003 01:50:12 -0000.
> --- In mapserver-users at yahoogroups.com, "Lowell Filak" <lfilak at m...>
wrote:
> > The tcheck.pl sample does the same thing but I have not tested it in
4 yet.
> > Try "undef $lineObj;" before doing the queryByShape, I noticed it in the
> > tcheck.pl code and don't remember if it is there for just such an issue
> > or if this is something new in 4.
> sorry, but didn't do anything. In any case, I am making the circle in
a sub-routine, so
> the lineObj doesn't really influence anything.
> I get the same kind of erroneous results. So, could this be something
buggy going on
> in the queryByShape code?
> > The following message was sent by "Puneet Kishor"
> > <pkishor at g...> on Thu, 25 Sep 2003 15:00:55 -0500.
> > > Hi Lowell,
> > > Thanks for you reply.
> > > > -----Original Message-----
> > > > From: Lowell Filak [mailto:lfilak at m...]
> > > > The code you sent before actually constructed a shapeObj instead
of a
> > > > rectObj for the queryByRect.
> > > > This is probably a legal thing to do but I just have to ask -
are you
> > > > sure the queryByRect is producing the correct result?
> > > Yeah, I think I mistyped the code in my email message, however, the
> > > problem still exists. Here is what I do... I create a circle shape
with
> > > its origin on the mouse click, and use it to select features from
> > > another layer. I have $x0, $y0, and $radius (in map units, of course).
> > > my $idlayerObj = getLayerByName("somelayer");
> > > my $shpObj = new mapscript::shapeObj($mapscript::MS_SHAPE_POLYGON);
> > > my $lineObj = new mapscript::lineObj();
> > > my $pointObj = new mapscript::pointObj();
> > > # make a circle
> > > for (my $i = 0; $i <= 360; $i = $i + 10) {
> > > $pointObj->{x} = $x0 + (cos($i * (22 / 7) / 180) * $radius);
> > > $pointObj->{y} = $y0 - (sin($i * (22 / 7) / 180) * $radius);
> > > $lineObj->add($pointObj);
> > > $shpObj->add($lineObj);
> > > $idlayerObj->queryByShape($mapObj, $shpObj);
> > > my $numbyshape = $idlayerObj->{resultcache}->{numresults};
> > > The above results in $numbyshape equal to several hundred. That is
wrong
> > > given my data. So, I do the following --
> > > $shpObj->setBounds;
> > > my $rectObj = $shpObj->{bounds};
> > > $idlayerObj->queryByRect($mapObj, $rectObj);
> > > my $numbyrect = $idlayerObj->{resultcache}->{numresults};
> > > This results in $numbyrect being the more correct 10 or 12.
> > > Yup, the latter is correct... The data are essentially parcel
centroids
> > > being selected in a 200 ft radius of the mouse click... 10-12 parcels
> > > within a 400 feet diameter circle makes sense. Not only the latter
> > > selection is correct, the shape and the selected points also draw
> > > correctly... The circle with 10-12 centroids within that circle.
> > > Strange.
> > > > > I've added this in the bz as an enhancement request. Part of the
> > > > problem is that us
> > > > > non-developers still have to first figure out whether or not our
> > > > problem lies with us
> > > > > screwing up or with the code. We can only do that via the list. Of
> > > > course, once it is
> > > > > determined that indeed the problem is a "bug" then it can
> > > > be added to
> > > > the zilla.
> > > > > For example, I am still having a problem with queryByShape, and I
> > > > don't know if I am
> > > > > doing something wrong or if this is a bug.
> > > > > My problem is thus --
> > > > > creating an shapeObj and then using it to queryByShape
> > > > against a layer
> > > > returns way
> > > > > more results than should.
> > > > > getting the bounds of the above shape and creating a
> > > > rectObj and then
> > > > using
> > > > > queryByRect against the same layer returns the correct number of
> > > > results (way less
> > > > > than that returned by queryByShape).
> > > > > now, I have to first determine if I am doing something
> > > > obviously wrong
> > > > or if this is a
> > > > > bug. Then I can act accordingly.
> > > > > Many thanks.
> > > > > _______________________________________________
> > > > > Mapserver-users mailing list
> > > > > Mapserver-users at l...
> > > > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Mapserver-users at lists.gis.umn.edu
