[Mapserver-users] Problem with MapFile and PostGIS
Vinko Vrsalovic
vinko at cprsig.cl
Mon Sep 29 20:58:42 EDT 2003
On Tue, Sep 30, 2003 at 12:40:19AM +0000, Andrés Collao wrote:
> now, the layer is turned ON. But they do not appear, even, i try with
> polygon, line and point with de same results.
Try setting DEBUG to ON in the layer and map objects, and in the WEB object
set the LOG property to a web-server writable location.
That way you can see if there's an error being raised.
Have you upgraded PostGIS too?
Vinko Vrsalovic <el[|- at -|]vinko.cl>
http://www.cprsig.cl
