[Mapserver-users] Problem with MapFile and PostGIS
Michael Roach
burntmage at yahoo.com
Mon Sep 29 23:01:34 EDT 2003
--0-1855730295-1064890894=:75477
Content-Type: text/plain; charset=us-ascii
Set the status to Default in the map file. I had the same trouble a while back with MS 4.0.
STATUS DEFAULT
Andrés Collao <collao_andres at hotmail.com> wrote:
now, the layer is turned ON. But they do not appear, even, i try with
polygon, line and point with de same results.
::: Andrés Collao Pérez :::
[ collao_andres at hotmail.com ]
[ andres at mapserver.cl ]
:::El hombre es un Dios cuando sueña y un mendigo cuando reflexiona.
:::Il peggior nemico del succeso è la pauta del fallimiento
:::El peor enemigo del éxito es el miedo al fracaso
----Original Message Follows----
Reply-To: vinko at cprsig.cl
To: Andrés Collao
CC: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Problem with MapFile and PostGIS
Date: Mon, 29 Sep 2003 20:38:38 -0400
On Mon, Sep 29, 2003 at 10:36:05PM +0000, Andrés Collao wrote:
> I have installed Mapserver4, when reading a SHAPE is no problem, but when
> reading and showing a LAYER whose data comes from a POSTGRES/POSTGIS
these
> simply they do not appear...
> These worked in version 3,6,6 of Mapserver
> this is a mapfile code
> LAYER
> CONNECTIONTYPE postgis
> NAME "ascensores"
> CONNECTION "user=admin password=administrador dbname=valparaiso
> host=localhost"
> STATUS OFF
the layer is turned off :-)
Vinko Vrsalovic
http://www.cprsig.cl
_________________________________________________________________
Charla con tus amigos en línea mediante MSN Messenger:
http://messenger.yupimsn.com/
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Do you Yahoo!?
The New Yahoo! Shopping - with improved product search
Content-Type: text/html; charset=us-ascii
<DIV>Set the status to Default in the map file. I had the same trouble a while back with MS 4.0. </DIV>
<DIV> </DIV>
<DIV>STATUS DEFAULT</DIV>
<DIV><BR><B><I>Andrés Collao <collao_andres at hotmail.com></I></B> wrote:</DIV>
<BLOCKQUOTE class=replbq style="PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #1010ff 2px solid"><BR>now, the layer is turned ON. But they do not appear, even, i try with <BR>polygon, line and point with de same results.<BR><BR>::: Andrés Collao Pérez :::<BR>[ collao_andres at hotmail.com ]<BR>[ andres at mapserver.cl ]<BR><BR>:::<BR>:::El hombre es un Dios cuando sueña y un mendigo cuando reflexiona.<BR>:::<BR>:::Il peggior nemico del succeso è la pauta del fallimiento<BR>:::El peor enemigo del éxito es el miedo al fracaso<BR>:::<BR><BR><BR><BR><BR><BR>----Original Message Follows----<BR>From: Vinko Vrsalovic <VINKO at CPRSIG.CL><BR>Reply-To: vinko at cprsig.cl<BR>To: Andrés Collao <COLLAO_ANDRES at HOTMAIL.COM><BR>CC: mapserver-users at lists.gis.umn.edu<BR>Subject: Re: [Mapserver-users] Problem with MapFile and PostGIS<BR>Date: Mon, 29 Sep 2003 20:38:38 -0400<BR><BR>On Mon, Sep 29, 2003 at 10:36:05PM +0000, Andrés Collao wrote:<BR>> I have installed Mapserver4, when reading a SHAPE is no
problem, but when<BR>> reading and showing a LAYER whose data comes from a POSTGRES/POSTGIS <BR>these<BR>> simply they do not appear...<BR>><BR>> These worked in version 3,6,6 of Mapserver<BR>><BR>> this is a mapfile code<BR>><BR>> LAYER<BR>> CONNECTIONTYPE postgis<BR>> NAME "ascensores"<BR>> CONNECTION "user=admin password=administrador dbname=valparaiso<BR>> host=localhost"<BR>> STATUS OFF<BR><BR>the layer is turned off :-)<BR><BR><BR>--<BR>Vinko Vrsalovic <EL[|- at -|]VINKO.CL><BR>http://www.cprsig.cl<BR><BR>_________________________________________________________________<BR>Charla con tus amigos en línea mediante MSN Messenger: <BR>http://messenger.yupimsn.com/<BR><BR>_______________________________________________<BR>Mapserver-users mailing list<BR>Mapserver-users at lists.gis.umn.edu<BR>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users</BLOCKQUOTE><p><hr SIZE=1>
Do you Yahoo!?<br>
<a href="http://shopping.yahoo.com/?__yltc=s%3A150000443%2Cd%3A22708228%2Cslk%3Atext%2Csec%3Amail">The New Yahoo! Shopping</a> - with improved product search
--0-1855730295-1064890894=:75477--
