[Mapserver-users] Problem with MapFile and PostGIS
Andrés Collao
collao_andres at hotmail.com
Mon Sep 29 21:01:55 EDT 2003
thanks.. I try with PostGIS 0.7.5; now I compiled with 0.7.3
::: Andrés Collao Pérez :::
[ collao_andres at hotmail.com ]
[ andres at mapserver.cl ]
:::El hombre es un Dios cuando sueña y un mendigo cuando reflexiona.
:::Il peggior nemico del succeso è la pauta del fallimiento
:::El peor enemigo del éxito es el miedo al fracaso
----Original Message Follows----
Reply-To: vinko at cprsig.cl
To: Andrés Collao <collao_andres at hotmail.com>
CC: vinko at cprsig.cl, mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Problem with MapFile and PostGIS
Date: Mon, 29 Sep 2003 20:58:42 -0400
On Tue, Sep 30, 2003 at 12:40:19AM +0000, Andrés Collao wrote:
> now, the layer is turned ON. But they do not appear, even, i try with
> polygon, line and point with de same results.
Try setting DEBUG to ON in the layer and map objects, and in the WEB object
set the LOG property to a web-server writable location.
That way you can see if there's an error being raised.
Have you upgraded PostGIS too?
Vinko Vrsalovic <el[|- at -|]vinko.cl>
http://www.cprsig.cl
_________________________________________________________________
¿Estás buscando un auto nuevo? http://www.yupimsn.com/autos/
